Author Topic: Not starting  (Read 1334 times)
Not starting
« on: 04 February 2009, 08:50:08 »
Car is turning over but won't fire into life, new battery so it isn't that, got any idea's what it could be?
Re: Not starting
« Reply #1 on: 04 February 2009, 09:02:29 »
Do the paperclip test ;)
MutantCav
  • Gainsborough
Re: Not starting
« Reply #2 on: 04 February 2009, 09:06:01 »
As Pete says...paperclip it...19 is crankshaft sensor (just for info  ;) )
Re: Not starting
« Reply #3 on: 04 February 2009, 09:09:45 »
Just found that there is no spark any idea's what that could be?
Re: Not starting
« Reply #4 on: 04 February 2009, 09:11:36 »
Do the paperclip test until then its just guess work. I guess you will get a 19 ;)
Re: Not starting
« Reply #5 on: 04 February 2009, 09:12:38 »
Crank sensor?
What does the paper clip test show?
MutantCav
  • Gainsborough
Re: Not starting
« Reply #6 on: 04 February 2009, 09:21:32 »
Paperclip test...unbend a paperclip and stick one end in pin 4 the other in pin 6 (for your 3.0 v6)...will flash out the codes...pin 1 being top right pin 2 being the one immediately below it and so on...
Re: Not starting
« Reply #7 on: 04 February 2009, 09:23:34 »
Gonna try a crank sensor today, I can see the crank sensor if I right it's under neath the oil filter. Where is the plug to it (is it a pig to get too)? If it's no spark could it be a crank sensor?
MutantCav
  • Gainsborough
Re: Not starting
« Reply #8 on: 04 February 2009, 09:47:23 »
Yes mate and the other end is behind the backpassenger corner of the plenum...
Re: Not starting
« Reply #9 on: 04 February 2009, 09:54:39 »
Is it just a simple case of unplugging them? Also could this be the reason it won't start?
Re: Not starting
« Reply #10 on: 04 February 2009, 13:30:41 »
New crank sensor sorted it now. Running sweet, EML light came on, found a plug was knocked off turned car off still on, turned off again took key out off now Cheers for the help guys  :y :y
