Author Topic: Brake pad wear indicator  (Read 1045 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« on: 04 February 2009, 19:45:16 »
Does this just slot into the gap in the caliper or do I need to remove the caliper.
Re: Brake pad wear indicator
« Reply #1 on: 04 February 2009, 20:05:24 »
caliper needs to be lifted up, the sensor actually clips into the brake pad itself, the wire then comes out through the gap in the caliper
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 04 February 2009, 20:07:36 »
Thought so, oh well need to wait till the weather improves.
hotel21
  • The Kingdom of Fife
« Reply #3 on: 04 February 2009, 20:12:31 »
I managed to fit my wear sensors by removing the wheel and carefully placing the sensors into place and gently levering them home, thus no need to unbolt the caliper again.....
edit - thats through the gap in the caliper.....  ;)
extra edit -. and with new pads....
« Last Edit: 04 February 2009, 20:20:43 by hotel21 »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #4 on: 04 February 2009, 20:36:26 »
Just replaced with new pads last week so was hoping to just slot it into the caliper without having to take it off.
hotel21
« Reply #5 on: 04 February 2009, 20:46:14 »
If you are carefull, you should be fine.  Remember the plastic of the sensors is quite fragile so, softly and cleverly when levering into place....     :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #6 on: 04 February 2009, 20:47:45 »
Cheers
