Author Topic: Brake cleaning  (Read 1254 times)
bighed
  • Shropshire
Brake cleaning
« on: 05 February 2009, 23:58:03 »
I want to remove the brakes off my senny, clean them uop and then paint them. Have seen other people do it but never done it myself. Is there a how to anywhere or can someone help on this one please?   :y
Brake cleaning
« Reply #1 on: 06 February 2009, 09:50:19 »
[movedhere] General Chat [move by] TheBoy.
  • Online Online
Re: Brake cleaning
« Reply #2 on: 06 February 2009, 12:05:47 »
Clamp the flexi brake hose. Remove top of caliper, like a pad change, then there are only 2 bolts holding the caliper on to the hub.
Gunson's Easi-bleed is easiest to use afterwards when you bleed the system.  :y
I can give you some paint to do my Omega's when you've practiced with your car
ians
  • Reading
Re: Brake cleaning
« Reply #3 on: 06 February 2009, 12:12:06 »
I tried to do this last time I changed pads.  But the hose is so hard - although flexy it wasn't compressible - that the clamping tool made no impression on it.
  • Online Online
Re: Brake cleaning
« Reply #4 on: 06 February 2009, 12:24:27 »
Standard hoses, or braided 'go-faster' hoses? I'm surprised standard hoses wouldn't compress enough to be clamped. Failing that, remove master cylinder cap, and trap a plastic sheet/carrier bag under it. That should be enough to stop fluid from draining from the system when the caliper is removed.
