Author Topic: drivers door wont lock on fob  (Read 1313 times)
Mr Stud
  • somerset
« on: 06 February 2009, 08:52:43 »
have just got me a MV6 manual 8-) :)...but got a couple little probs to sort out.....the main major fault is that the drivers door won't lock/unlock on the remote fob(all other doors do)but will lock/unlock on the key in the lock along with all the other doors....is the central locking motor at fault even though it locks with all the doors on the key....
hope that all makes sense :)
thanks
MutantCav
  • Gainsborough
Re: drivers door wont lock on fob
« Reply #1 on: 06 February 2009, 08:54:30 »
Yes mate door locking motor...
With the key it will manually shut, with the fob there is no manual intervention so then requires the locking motor to lock the door...
unlucky alf
  • worksop, notts
« Reply #2 on: 06 February 2009, 08:56:00 »
i would imagine it is the motor as using the key you are operating it manually so it would lock ;)
Mr Stud
  • somerset
« Reply #3 on: 06 February 2009, 08:56:09 »
bloody hell that was quick :y..wait ages on some forums for a reply....
thanks....now to hunt down a motor....
Welung666
« Reply #4 on: 06 February 2009, 11:33:51 »
This ain't no 'other forum'! This is the best ;) :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #5 on: 06 February 2009, 12:41:28 »
Its probably a faulty actuator in drivers side door or its come loose from the connection inside door panel you need to remove door panel to get too it and or fit a replacement (often able to buy 2nd hand for a tenner on here on egay
There is links to do job on here heres one for later models but will be similar one for earlier models..
http://www.omegaowners.com/forum/YaBB.pl?num=1175610013
http://www.omegaowners.com/forum/YaBB.pl?num=1177492197
Mr Stud
  • somerset
« Reply #6 on: 06 February 2009, 14:17:04 »
for omegas ;)
« Last Edit: 06 February 2009, 14:26:17 by Mr_Stud »
Mr Stud
  • somerset
« Reply #7 on: 06 February 2009, 14:24:43 »
cool thanks....mines a 2000 w reg so is that a later one(facelift)
« Last Edit: 06 February 2009, 14:25:52 by Mr_Stud »
