Author Topic: Fitting Cruise Control  (Read 3465 times)
Big Sye
  • SLady bitshorpe, South Humberside
  • Hero's Don't Die!!! - They Reload!!!
« on: 06 February 2009, 19:38:44 »
hey all who may be able to help.  i have just been readin through some of the technical posts,  i was wonderin if it is possible to fot cruise control to my omega.
i have a 2000 w reg 3.0l MV6 estate Manual.
can it be done to add the cruise control function to it.??
thanks  sye
 :question
Big Sye
(Midnight-Modified.co.uk)
Re: Fitting Cruise Control
« Reply #1 on: 06 February 2009, 19:39:35 »
thanks  sye
 :question
Yes!  :y
Big Sye
« Reply #2 on: 06 February 2009, 19:42:57 »
ok great stuff.  just an extra feature id like to add to my omega beast.  motorway lazyness.
is there anything special that needs to be done  other than replacing my indicator switch with one with cruise control on it.
Big Sye
Iain
« Reply #3 on: 06 February 2009, 19:46:09 »
Once the stalk fitted mate you will need to plug it in to a Tech 2 to activate it
 :y :y
Omega man 2
« Reply #4 on: 06 February 2009, 19:48:56 »
Wait, hang on :o. If you has a 3.0 and not a 3.2 (no drive by wire) wouldn't you need the actuator? :-?
Big Sye
« Reply #5 on: 06 February 2009, 19:51:22 »
oh right.  ni have heard of that before.  is that a vauxhall garage job or does someone have one of there own??
Big Sye
« Reply #6 on: 06 February 2009, 19:54:06 »
Ian is confusing your car with a drive by wire 2.6/3.2. You need the actuator under the bonnet, cable and  ...... ????
The lads breaking cars will put you straight!  :y
« Last Edit: 06 February 2009, 19:54:27 by Andy_B »
Iain
« Reply #7 on: 06 February 2009, 19:55:21 »
Ooops sorry......
« Reply #8 on: 06 February 2009, 19:57:27 »
Ooops sorry......
You'll have to stand facing the corner for 20 mins!  ;D  ;D  ;D  ;D
Iain
« Reply #9 on: 06 February 2009, 20:00:03 »
I thought i was doing well then....couldnt type it quick enough!!
Thats what i get.........
Now then where's my pointy hat with the D on it?? :-/
jonathanh
  • coventry
« Reply #10 on: 06 February 2009, 20:32:45 »
right, you need a stalk, actuator unit from a v6 (to get the right length cable) and possibly a clutch switch.
No need to go to vauxhall, just plug them in and off you go.  The clutch switch at the top of the clutch pedal (pig to get to) there is usually a multiplug there.  stalk, easy - again find the extra multiplug
the actuator goes below the header tank in the engine bay (you may also have an aux water pump there but you can adapt it onto the auctator housing.  multiplup is on the top of the driver side top strut mount.  connect the bowden cable and off you go
there is a how to on here somewhere
« Reply #11 on: 06 February 2009, 20:43:49 »
Tada!
Onkel Per
  • Frederikshavn - Denmark
« Reply #12 on: 06 February 2009, 20:52:43 »
The stalk and Acturtor is the same as for Vectra.
I have even built on into my Cavalier. Pic's: http://www.olsenworld.dk/opel/goerdetselv/fartpilot/fp-samling.asp
hotel21
  • The Kingdom of Fife
« Reply #13 on: 06 February 2009, 21:15:31 »
http://www.omegaowners.com/forum/YaBB.pl?num=1166374649
markey mark
  • SLady bitshorpe north lincs
« Reply #14 on: 06 February 2009, 21:17:08 »
pop round sye and see me have all the parts you will need bud !  :y
