Author Topic: Very strange - wheels spinning  (Read 1094 times)
chrisdb
  • Chesterfield
« on: 08 February 2009, 08:38:42 »
Hi all
Is it normal for the rear wheels to spin (quite fast) when the car is jacked up with the engine running in neutral on the 3.0 Elite auto?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
Omegatoy
  • UK
Re: Very strange - wheels spinning
« Reply #1 on: 08 February 2009, 08:54:16 »
yep its transmission drag, in other words its the viscosity f the trnsfluid transferring the engine motion thru the trans to the rear wheels :y wont do it in park tho!!!
chrisdb
  • Chesterfield
« Reply #2 on: 08 February 2009, 09:02:18 »
Ah ha... Thanks  :y
Iain
« Reply #3 on: 08 February 2009, 11:52:47 »
All cars will 'Drive' when the drive wheels are lifted,
We have done work on cars,gearboxes,clutches etc and then 'drove' them on the stands to make sure everything is ok before putting it all back together.....
Strange though when you run the car through the gears and the speedo and rev counter etc all go up and your not moving!
 ;D
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 08 February 2009, 12:07:07 »
Bear the following in mind though ...........
If yours has a limited-slip diff, ensure BOTH drive wheels are lifted, (and securely supported), clear of the ground.
