Author Topic: odd noise n/s/f  (Read 2995 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
odd noise n/s/f
« on: 07 February 2009, 17:00:43 »
seem to have an odd metalic grating noise from the front n/s on left turns. only does it when travelling forwards. have jacked the front up, spun the wheel & no noise. cant see anything rubbing & have also bent the disc backing plate out a little. any idea`s please?.  :y
largecol
  • Middlesbrough
  • I cant see my socks!!
Re: odd noise n/s/f
« Reply #1 on: 07 February 2009, 17:07:20 »
I would probly start by havin a quick look at the brake shoe/disc condition, then possibly wheel bearing?
Pssssst! The man in my avatar aint really me!!
The Red Baron
Re: odd noise n/s/f
« Reply #2 on: 07 February 2009, 17:08:44 »
discs fine & the pads have loads of meat on em :y
largecol
  • Middlesbrough
Re: odd noise n/s/f
« Reply #3 on: 07 February 2009, 17:08:51 »
Sorry i mean brake PADS doh!!!
largecol
  • Middlesbrough
Re: odd noise n/s/f
« Reply #4 on: 07 February 2009, 17:12:38 »
When its off the ground is there any freeplay on the wheel? Could be the old wishbone issue?
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
Re: odd noise n/s/f
« Reply #5 on: 07 February 2009, 17:27:07 »
I had that problem on my old 2.0 estate and it was worn wisbone rubbers allowing the tyre to just snag the mudflap when turning left, new wisbones cured the problem.
Worth checking if you have mudfaps, if not I don't know what the problem is.
Re: odd noise n/s/f
« Reply #6 on: 07 February 2009, 17:28:53 »
My money's on wishbones Jon :y :y :y
Beconboy
  • DAGENHAM
    • 2000 3.0 OMEGA ELITE
Re: odd noise n/s/f
« Reply #7 on: 07 February 2009, 17:33:05 »
if it was wishbones John wouldn,t they have fond that on mot?
The Red Baron
Re: odd noise n/s/f
« Reply #8 on: 07 February 2009, 17:44:37 »
paul, its just gone through an mot & no mention of wishbones on it. got me baffled this one has.  :o
Re: odd noise n/s/f
« Reply #9 on: 07 February 2009, 17:58:43 »
Didn't realise it's just been mot'd... Still check them though... Front bush :y :y
Wouldn't be the first time an MOT tester has missed something ::) ::)
Other than that... Start checking everything methodically :y :y
razzo
  • Crapital
    • 97 3.0 Elite
Re: odd noise n/s/f
« Reply #10 on: 07 February 2009, 18:54:01 »
have you checked wheel bearings Jon
largecol
  • Middlesbrough
Re: odd noise n/s/f
« Reply #11 on: 07 February 2009, 18:59:20 »
Wishbones only fail MOT if freeplay is excess - could still be enough to cause noise, i agree about the bearing check tho. ;)
The Red Baron
Re: odd noise n/s/f
« Reply #12 on: 07 February 2009, 19:23:04 »
I will have a check tommoz. doesnt seem like a bearing noise though. will be just my luck to get loads of snow tommorow. oh hum.  ;)
RichB
  • Loughborough
Re: odd noise n/s/f
« Reply #13 on: 07 February 2009, 21:41:39 »
Mudflaps are fouling the tyres, I have just had exactly the same problem.  New wishbones and full alignment made it better, but I took the mudflaps off this afternoon and now its gone  :y
Cheers,
Richard
The Red Baron
Re: odd noise n/s/f
« Reply #14 on: 07 February 2009, 21:56:10 »
No mudflaps fitted.
