Author Topic: Paperclip test  (Read 1222 times)
V6CDBOY
  • Wiltshire
Paperclip test
« on: 08 February 2009, 14:45:32 »
Hi all,
Just done a paperclip test on my 2001 2.6 v6 CD and the result is a continuous flashing orange light.
Can anyone let me know what this indicates.
Cheers
Re: Paperclip test
« Reply #1 on: 08 February 2009, 14:46:12 »
Hi all,
Cheers
paperclip or pedal trick test? you can't paperclip 2.6
V6CDBOY
  • Wiltshire
Re: Paperclip test
« Reply #2 on: 08 February 2009, 14:47:07 »
Sorry Pedal trick
Re: Paperclip test
« Reply #3 on: 08 February 2009, 14:59:58 »
Sorry Pedal trick
not come across a 2.6/3.2 without fault codes, but suspect it means no codes stored.
MutantCav
  • Gainsborough
Re: Paperclip test
« Reply #4 on: 08 February 2009, 15:00:34 »
constant fast flashing means immobiliser signal not being received...
Are you sure your reading it correctly...should get for example 10 flashes followed by a slight gap then maybe another ten flashes (10 represents 0) and so on...
Re: Paperclip test
« Reply #5 on: 08 February 2009, 15:03:17 »
not in this case. If it was immobiliser, it would flash when trying to start, but would flash out immobiliser fault code during pedal trick
Re: Paperclip test
« Reply #6 on: 08 February 2009, 17:52:49 »
Pedal trick on DBW.. continuous flashing = no stored faults .. this has been confirmed on mine using both the ELM327 and the MaxScan .. :)
HTH
MutantCav
  • Gainsborough
Re: Paperclip test
« Reply #7 on: 08 February 2009, 18:24:24 »
Live and learn  :y
Re: Paperclip test
« Reply #8 on: 08 February 2009, 19:10:56 »
constant flasshing equals no codes as said, no codes on  mine since Kevin wood tech 2d it to clear speed sensor code that had cleared itself anyway.  ;D  :y
V6CDBOY
  • Wiltshire
Re: Paperclip test
« Reply #9 on: 08 February 2009, 20:13:41 »
Cheers Guys
