Author Topic: passenger side wheel/suspension  (Read 3596 times)
Loch View
  • Dumbarton, Scotland
Re: passenger side wheel/suspension
« Reply #15 on: 06 February 2009, 20:31:18 »
yet another ?
Is it only the front brake pads that have a sensor or also the rears?
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
« Reply #16 on: 06 February 2009, 22:19:22 »
just the fronts have sensors. Buy some new ones when you get the pads(from vx) they are brittle and almost impossible to remove with out breaking first time you do it, and from memory, dont attach the sensors until you are sure the pads are assembled with sensor wire routed correctly. Seem to remember haveing to do it over again with the correct routing or something like that.
Your handeling issues are to be expected with a 12 year old car, in the last 18 months a mate and i have done wishbones and bushes on my 03 omega,my old 99 omega, my father in laws y2k c70, my mates 02 e39 and his mates e39. Rubber bushes do not last for ever. Those who have had no issues imho probably have just not noticed the deterioration.
So anyway, suggest you ring Tony at Wim, 07948427383 and have a chat. Hes a good lad, knows his onions, and will take time to explane and probably recommend the nearest company near you if possible.
 For info, basic procedure is, check for broken springs, worn steering idler, buggerd wishbone bushes(yours WILL need doing) and also rear donut bushes in the rear trailing arms.(triangular plate under rear doors) change any shocks that you think need doing, once all faults are rectified THEN take the car for a full geometry set up. Any subsequent change of parts can alter the set up. So, find the faults, rectify, then set up, preferably with new tires at the same company. Sounds like a lot but its worth doing, it will transform the car. :-)
 Hth
Loch View
« Reply #17 on: 06 February 2009, 22:49:28 »
Thanks for that Chris.
I'll have a bit of a fiddle with the car tomorrow to see what all needs replacing.
Will keep you informed.
Loch View
« Reply #18 on: 07 February 2009, 09:46:05 »
Has anyone seen a write up on changing the cam belt? I've looked but could't find it.
As there is no record in the history when the belt was changed, I figure I better do it myself.
Just wanting to know if there are any fiddly bits to take into account :)
« Reply #19 on: 07 February 2009, 09:51:31 »
Start a new topic on that one mate, youll get better replys. :-)
Loch View
« Reply #20 on: 07 February 2009, 10:06:57 »
agreed.
Will do
Loch View
« Reply #21 on: 07 February 2009, 12:00:27 »
well....
After some fiddling I have found that both sides the wishbone bushes are knackered. Also the 2 front tyres are worn excessively on the inside (the metal is coming through )
The passenger side wheel bearing has excessive play as well and last but not least...there are 2 different types of profile tyres in the front: passenger side is 205/65 R15 and the other side is 205/55 R15  :o
Loch View
« Reply #22 on: 08 February 2009, 20:19:35 »
I was just going over the FAQ section and there was something about the springs getting weak over time and causing too much neg camber.
Has anyone here had that happening to their car?
Page created in 0.008 seconds with 16 queries.
