Author Topic: passenger side wheel/suspension  (Read 3382 times)
Loch View
  • Dumbarton, Scotland
« on: 06 February 2009, 12:11:47 »
Hello  :)
I have just purchased my first Omega and have a few issues. I was wondering if anyone could help.
The problem is, the car is pulling quite strongly to the left and there is also a noise coming from the passenger side front.
I'm not really sure whether this is the bearing on it's way out or something else. I'm also feeling like a sort of 'scraping' at the steering wheel.
When looking at the front wheel (not very clear on pic) it looks as if the camber is way out.
Any thoughts ?
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
Loch View
Re: passenger side wheel/suspension
« Reply #1 on: 06 February 2009, 14:03:14 »
I also just noticed that (especially the passenger side) the front wheels wear unevenly, more wear on the inside.
Welung666
« Reply #2 on: 06 February 2009, 14:04:44 »
Welung666
« Reply #3 on: 06 February 2009, 14:05:18 »
Use the IMG tags on photobucket :y
unlucky alf
  • worksop, notts
« Reply #4 on: 06 February 2009, 14:08:57 »
definately check the bearings first, also depending on what wheels & tyres combo you have they can rub on the strut itself if its that bad, could explain the noise, have a look at the tyre inner wall for scuffs :y
Loch View
« Reply #5 on: 06 February 2009, 14:19:16 »
lol..thanks Welung666, will do from now on ;)
I have checked the tyres on the inside, no scuffs or anything.
I wonder what causes the camber to be off though.. :-/.could it be the wishbone bushes?
« Reply #6 on: 06 February 2009, 14:20:38 »
Only guessing here as can't be sure but I think he's got standard tyres on 16" Elite rims so that should all be ok...
Firstly check wishbones and drop links... I reckon you'll find them knackered!
Then get yourself to Wheels In Motion in Chesham for a full geometry setup :y :y :y
Oh... And welcome ::) ::) :y :y :y
« Reply #7 on: 06 February 2009, 14:21:29 »
Oops... Just noticed you're in Scotland! I think Tony at WIM has recommended somewhere nearer to you :-/ :-/
« Reply #8 on: 06 February 2009, 14:22:56 »
Probably... Very common failure on the Omega as there's a lot of weight on a poor design of suspension ::) ::)
There's a good how to guide in the maintenance section :y :y
Loch View
« Reply #9 on: 06 February 2009, 14:33:23 »
thanks for the help sofar...
I'll have a good look tomorrow. Car up in the air, wheels off..much better view :)
Will let you know how it goes
« Reply #10 on: 06 February 2009, 14:36:32 »
Get a good lever bar or heavy screwdriver in around those bushes... I bet there's loads of play ::) ::) ::)
Loch View
« Reply #11 on: 06 February 2009, 14:43:47 »
will do :y
Loch View
« Reply #12 on: 06 February 2009, 14:49:59 »
Before I forget..
Are the wheel bearings A DIY job? I've done them before on a Porsche 924.
« Reply #13 on: 06 February 2009, 16:01:00 »
Before I forget..
http://www.omegaowners.com/forum/YaBB.pl?num=1175890350 :y
Loch View
« Reply #14 on: 06 February 2009, 17:42:15 »
Muchos gracias  :)
