Author Topic: fitting hids  (Read 3498 times)
nick v6
  • walsall / west midlands
fitting hids
« on: 05 February 2009, 21:29:16 »
ive been tod i can fit hids to my mig but will need to adjust wireing
can anybody tell me what wires need to be changed
thanks
Re: fitting hids
« Reply #1 on: 05 February 2009, 21:31:47 »
legally you cant
nick v6
Re: fitting hids
« Reply #2 on: 05 February 2009, 21:34:19 »
why's that
is it to do with head light washers
Re: fitting hids
« Reply #3 on: 05 February 2009, 21:34:26 »
To put HIDs on properly requires, in addition to the lights themselves ;
Headlight washing system
Automatic Headlight level adjusting system
A tremendous amount of work.
Better to fit ordinary "projectors" with a high output bulb
« Last Edit: 05 February 2009, 21:35:08 by entwood »
Re: fitting hids
« Reply #4 on: 05 February 2009, 21:36:18 »
why's that
Assuming you swap entire headlight, your only legal problems are washers and automatic levelling
nick v6
Re: fitting hids
« Reply #5 on: 05 February 2009, 21:37:51 »
so how much work is involved to fit projectors
Re: fitting hids
« Reply #6 on: 05 February 2009, 21:38:31 »
I believe it's a straight swap ... :)
nick v6
Re: fitting hids
« Reply #7 on: 05 February 2009, 21:39:14 »
how hard is it to fit the auto leveling for hids
Martin_1962
Re: fitting hids
« Reply #8 on: 05 February 2009, 21:40:46 »
Hmmm HIDs
Well I have projectors with bulbs, I fitted a HID kit and I have had no issues.
MOT passed
Police no interest - remember Omegas are sort of Police invisible
OK My thoughts
Make sure they won't dazzle - that said I am well fed up of being dazzled by a Range Rover with them on the way home from work and that is OE fit.
Keep those lamps clean - I am now after some washers, but TBH a damp rag is best.
Re: fitting hids
« Reply #9 on: 05 February 2009, 21:40:52 »
properly, a bit of a pain
Re: fitting hids
« Reply #10 on: 05 February 2009, 21:41:23 »
levelling sensor on rear suspension, levelling sensor on front suspension,  associated wiring if not present. The actual adjusting motors are inside the HID headlights.
Re: fitting hids
« Reply #11 on: 05 February 2009, 21:45:17 »
you've forgetting ecu. plus reprogramming of MID for alerts, not that an early one can be.....
nick v6
Re: fitting hids
« Reply #12 on: 05 February 2009, 21:45:36 »
Hmmm HIDs
MOT passed
OK My thoughts
do you think ill be fine fitting them going on from what you have said
Re: fitting hids
« Reply #13 on: 05 February 2009, 21:48:32 »
Re: fitting hids
« Reply #14 on: 05 February 2009, 21:49:10 »
Hmmm HIDs
MOT passed
OK My thoughts
Fitted responsibly, you're less likely to get pulled up...  ....though I'd always change the headlights rather than kits.
