Author Topic: slow running omega  (Read 1149 times)
christof
  • lincs
slow running omega
« on: 09 February 2009, 15:32:39 »
i have a 02 plate 2.2 sport auto runs grat normally
now and again if i have run it and stop and go back later it takes a while to start several turn over but does always start
car runs sluggish but changes gears ok
to fix it i pull over stop engine and restart all ok then
any ideas
MutantCav
  • Gainsborough
Re: slow running omega
« Reply #1 on: 09 February 2009, 15:48:33 »
Struggling to start may well be crank sensor, although could be battery or alternator failing...
Sluggish driving on an auto is usually low gearbox fluid
christof
  • lincs
« Reply #2 on: 09 February 2009, 15:58:25 »
thanks is it easy checking gearbox fluid
« Reply #3 on: 09 February 2009, 16:05:43 »
On a 2.2 its more likely to be the cam sensor actualy.
It needs the fault codes reading to confrm.
« Reply #4 on: 09 February 2009, 16:23:05 »
I would suspect cam sensor as well, fault code P0340.
Unfortunately, the only way to read the codes on a 2.2 is to plug it in a diagnostic tester.  Maybe a nearby member can read the codes for you for the price of a couple of pints?
christof
  • lincs
« Reply #5 on: 09 February 2009, 16:33:42 »
how easy is it to fit a new cam sensor on a 2.2  although its only happened 4 times in 14 months bur twice in the last 2 months
restart of the car sorts it out at the moment
« Reply #6 on: 09 February 2009, 18:12:19 »
very easy - cambelt cover off, and plug cover off :)
Get the codes read anyway before changing any parts...
« Reply #7 on: 09 February 2009, 21:33:24 »
update your profile so people know where you are, you maybe close to one of our members with tech2  :y
    • 530D M Sport, 330i Coupe
« Reply #8 on: 09 February 2009, 21:35:22 »
Sounds like Cam Sensor - Is it limited to 4500 RPM when it's acting sluggish?
