Author Topic: Not starting as it should  (Read 3704 times)
Dazzler
  • Haverhill, Suffolk
« on: 05 February 2009, 17:11:28 »
My Elite is taking a few cranks to get started from cold. It starts fine when warm.
From cold it seems to try and catch on all cranks, then does start but lumpy, once fully started it seems to be fine.
Now i have changed the HT leads and fitted GM plugs, leads are Lucus.
Any ideas??
Re: Not starting as it should
« Reply #1 on: 05 February 2009, 19:03:23 »
Any codes?
Dazzler
« Reply #2 on: 05 February 2009, 19:44:00 »
Any codes?
Sorry forgot to say, its code free, even on Tech2
« Reply #3 on: 05 February 2009, 20:58:48 »
I believe if theres no fault code then its down to the Dis pack, plugs or leads but I would wait for confirmation ;)
Dazzler
« Reply #4 on: 05 February 2009, 21:21:13 »
Ok Pete, thanks.
As said leads and plugs replaced and the dis pack is about 18months old......
« Reply #5 on: 05 February 2009, 23:53:35 »
What mileage?
How are the cylinder compressions, from cold and from hot?
Dazzler
« Reply #6 on: 06 February 2009, 11:24:48 »
What mileage?
Mileage is 128k, compressions unknown.........and not a job i would like todo either..lol
« Reply #7 on: 06 February 2009, 12:35:53 »
What mileage?
Compression testing isn't bad - it would be good to know the readings  :y
« Reply #8 on: 06 February 2009, 12:53:35 »
If you crank it for a few seconds with your foot flat on the floor before attempting to start normally does this help?
Dazzler
« Reply #9 on: 06 February 2009, 12:55:28 »
Not tried that Kevin.
Will give it a go and see what happens.
ps- still need to tie up and do mine and yours ;)
Dazzler
« Reply #10 on: 07 February 2009, 20:12:42 »
No difference at all Kevin :-/
« Reply #11 on: 07 February 2009, 20:16:49 »
estimation : fuel related issue..  problem related to pump or fuel lines..
« Reply #12 on: 07 February 2009, 20:38:44 »
Possibly a leaky injector?
Dazzler
« Reply #13 on: 07 February 2009, 21:41:49 »
How would find that then???
MutantCav
  • Gainsborough
« Reply #14 on: 07 February 2009, 22:11:41 »
Seen a post or 2 along these lines before...end result its a crank problem, crank sensor was on its way out...new crank sensor fixed it :)
