Author Topic: Cambelt change  (Read 1163 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Cambelt change
« on: 11 February 2009, 11:37:38 »
Managed to change the cambelt and water pump on my 2.2 without any major problems and with the help of the DVD. The only problem I have now is that the heaters not blowing any hot air. had it ticking over in the drive for about 15 minutes still frozen. Any easy solution or will it start after a good long drive. Cheers
Re: Cambelt change
« Reply #1 on: 11 February 2009, 12:05:45 »
Start it up from cold with the expansion cap removed and the heaters set to Hi......
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Cambelt change
« Reply #2 on: 11 February 2009, 12:17:52 »
Will give it a go. Was working fine prior to change.
Re: Cambelt change
« Reply #3 on: 11 February 2009, 12:19:35 »
As Mark is suggesting ... it'll be your heater matrix that's air locked.
Re: Cambelt change
« Reply #4 on: 11 February 2009, 12:41:13 »
How do I flush it. Dont even know were it is. New to Omegas
You don't need to flush it, you need to shift the air and get a flow of water through the matrix. It's in the middle of the car, above the transmission tunnel, you can see the pipes go througthe bulk head on the driver's side-ish of the car.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Cambelt change
« Reply #5 on: 11 February 2009, 15:16:37 »
Coming through now thanks for the advice.
