Author Topic: Engine Temperature  (Read 2176 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Engine Temperature
« on: 11 February 2009, 19:00:04 »
My engine temp gauge only goes up to between 80-85 ... i thought it should be a bit higher .... is this normal or could this be the problem causing my constant fuel trim issue ( P0170 ).
Thanks
Iain
Re: Engine Temperature
« Reply #1 on: 11 February 2009, 19:03:25 »
That what mine sits at mate  :y
hotel21
  • The Kingdom of Fife
« Reply #2 on: 11 February 2009, 19:04:08 »
Facelifts generally sit 80 - 85 then the fans cut it back.  As long as the needle is below half way all should be normal...
Dont think it will affect fuel trim but M_DTM or others may well know better....
« Reply #3 on: 11 February 2009, 19:04:37 »
mine stayed at 80-85 before I changed the thermostat .. :D
now 92-95..
« Last Edit: 11 February 2009, 19:05:40 by cem_devecioglu »
ScottieMV6
  • Swinton, Manchester
« Reply #4 on: 11 February 2009, 19:05:14 »
What about pre-facelifts? Mine sits at 90 ish all the time.
Sorry to hijack! ::)
I'd rather be scared to death than bored to death!!
hotel21
« Reply #5 on: 11 February 2009, 19:07:55 »
Guage numbers are different between pre and facelift.  80 on a facelift shows as 90 on a prefacelift for the same needle deflection.  As long as the needle is below half way(ish) thats fine....   ;)
Proz
« Reply #6 on: 11 February 2009, 19:09:24 »
Damn ... was hoping it would have been the cause of the fuel trim  :y
Proz
« Reply #7 on: 11 February 2009, 19:16:00 »
I must admit its always been in that area 80-85 but maybe my imagination or the cold weather but does seem to be a bit slower to heat up.
« Reply #8 on: 11 February 2009, 19:22:38 »
not sure but coolant temp.sensor may cause that code..
Proz
« Reply #9 on: 11 February 2009, 19:25:46 »
Yeah i thought it might but im just hoping i get a more specific code other than the fuel trim P0170 one day  :y
« Reply #10 on: 11 February 2009, 19:30:10 »
some sensors on the car give error codes for them only if they are complete dead.. but up to that point they mess up the system..
Proz
« Reply #11 on: 11 February 2009, 19:33:01 »
I just dont really want to start throwing money at it changing parts if its not going to solve the problem. :-/
« Reply #12 on: 11 February 2009, 19:36:17 »
agreed..meaning you have to wait more :-/
« Reply #13 on: 11 February 2009, 20:01:54 »
any members near you that you can swap maf's with, just to see?
Proz
« Reply #14 on: 11 February 2009, 20:13:14 »
There is a member near me how has kindly agreed to read the live data on his tech 2  :y.... i just need to get my finger out and find time to have it done  :y
