Author Topic: What causes this?  (Read 1332 times)
Ian_D
  • York
What causes this?
« on: 11 February 2009, 22:42:19 »
http://www.youtube.com/watch?v=hQlXZ3wNWlA&feature=related
My Omega does this, and ive always wondered why. Is it normal (guess it shouldnt be!)? Mine has a flat spot around 4.5k just like the vid above which i've just found!  :-[
[size=12]
Re: What causes this?
« Reply #1 on: 11 February 2009, 22:55:03 »
multi rams? One or other not working. Maybe?
Not seen it that dramatic though.
Ian_D
  • York
« Reply #2 on: 11 February 2009, 23:33:34 »
Mine has its moments... Most of the time its like it is on the video, however somedays its worse  :-/
I'm sure there working, however the EML is on and last time I checked it was something to do with the air valves - However I cant see anything wrong with them. Checked for leaks etc, and pipes are fitted correctly too.
[size=12]
« Reply #3 on: 11 February 2009, 23:54:25 »
Paperclip it, post the codes, see what people say.
Have you tried blipping the throttle from the engine bay? Should see them move, but need to get the revs up t o same level as on video. From memory i think the one back of plenum is the one to watch. If its the front one on bag pipes its flat below 4.5 k then takes off above that. So reverse of the video. Would be nice if someone else would confirm, dont want to waste your time.
« Reply #4 on: 11 February 2009, 23:58:07 »
ps these can be activated via tech 2 for a diagnostic test if your ever near one Jamies magic machines.
« Reply #5 on: 12 February 2009, 08:39:01 »
IIRC front rams for 4.5K and >, back should move > 1K rpm.
