Author Topic: explaining a fault code - hopefully  (Read 1062 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 13 February 2009, 14:18:10 »
fuel quantity control out of range- fault code 64 -- can anybody explain what this may mean please
Re: explaining a fault code - hopefully
« Reply #1 on: 13 February 2009, 17:32:41 »
You don't want to know the answer  :'(
But, before you replace the Fuel Injection Pump, try some neat diesel magic in the fuel filter first.
« Reply #2 on: 13 February 2009, 17:33:22 »
Incidentally, is it a manual or auto, and if manual, tend s to do it in lower gear, or when changing into or out of 2nd?
raywilb
    • Citroen C4 Cactus
« Reply #3 on: 13 February 2009, 18:38:27 »
manual , sorry i forgot to say.
« Reply #4 on: 13 February 2009, 19:36:23 »
Yeah, thats what I guessed, along with your PM.  That seems to be the common symptoms.
Try the diesel magic trick as mentioned earlier, if that doesn't work, then you have a huge problem.
