Author Topic: V6 Cam gasket kit  (Read 2145 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
V6 Cam gasket kit
« on: 11 February 2009, 19:23:41 »
Bought the cam cover gasket kit from the oof shop :y
Kit doesn't come with all the gaskets mentioned in Mdtm's guide, so am i to assume that the 3 missing items are not to be replaced but refitted? :-?
Inlet Bridge to head 90501652 2off
Inlet to inlet Bridge  90501653 3off
Inlet to Plenum O rings 9118135 6off
Or do i need to source these myself from local stealer? and if so how much are they?
cheers guys :y
Re: V6 Cam gasket kit
« Reply #1 on: 11 February 2009, 19:27:12 »
cheers guys :y
Re-use, yet to see a car that needed them replacing plus they will double the cost.
Glad they arrived ok!
HerefordElite
  • Hereford
« Reply #2 on: 11 February 2009, 19:32:00 »
Ah the man himself!
Yeah all present and correct cheers Mark :y
Next question is how do i guess 8Nm with my 20Nm torque wrench? ::)
    • 530D M Sport, 330i Coupe
« Reply #3 on: 11 February 2009, 19:33:23 »
Ah the man himself!
You nip down to HellFrauds and buy their 'low range' torque wrench... or if your passing this way you can borrow mine.
HerefordElite
  • Hereford
« Reply #4 on: 11 February 2009, 19:35:30 »
Ah the man himself!
i've been looking at them on egay but seems only the expensive ones go down so low :-/
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 11 February 2009, 19:40:11 »
1/4 drive rachet 8mm socket hand tight  :y
HerefordElite
  • Hereford
« Reply #6 on: 11 February 2009, 20:01:12 »
My E12 torx socket is 3/8 drive - hand tight with no wrench on the end then?
« Reply #7 on: 11 February 2009, 20:06:51 »
too easy to get wrong, borrow/buy torque wrench :)
HerefordElite
  • Hereford
« Reply #8 on: 11 February 2009, 20:33:09 »
back to partco tomorrow then ::)
HerefordElite
  • Hereford
« Reply #9 on: 14 February 2009, 10:23:46 »
update:
bought a low range torque wrench after from here :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200309474146&ssPageName=ADME:B:WNARL:GB:1123
Phoned them up and got it delivered next day for the same del charge.
Well pleased :y
right outside now to test it out :)
