Author Topic: Onboard phone  (Read 1450 times)
Black Knight
  • York
Onboard phone
« on: 14 February 2009, 11:00:48 »
Blagged a sim card of a mater today and managed to get the phone function working. Very impressed. I found there was a lot of noise when making a call and not sure I was heard that well either.
Where abouts the the microphone reciever fitted? I'm sure if I spoke towards it sound quality would be improved.
Also, couldn't seem to adjust th volume - Had the use rotary controller, I'm assuming that the volume control, but didn't seem to have any effect.
Ta.
Re: Onboard phone
« Reply #1 on: 14 February 2009, 11:04:34 »
Courtesy light.  :y
Black Knight
  • York
Re: Onboard phone
« Reply #2 on: 14 February 2009, 11:11:40 »
Cheers.
Re: Onboard phone
« Reply #3 on: 14 February 2009, 12:57:35 »
The noise in mind was horrendous and noone could hear a thing... Popped the courtesy lamp out as i was going to fit a nokia kit and when i put it back together it all worked perfectly ::) ::) :y :y
Re: Onboard phone
« Reply #4 on: 14 February 2009, 14:24:54 »
ccrt700? Pop it out for a couple of hours (if you have the radio code) - these are problematic...
Black Knight
  • York
Re: Onboard phone
« Reply #5 on: 14 February 2009, 14:28:22 »
Yes its the 700.
I'll look at getting a removal tool. Prob try and do it in conjunction with the console lamps as a couple of those are out.
The RH side temp contol lamp is out (I assume thats one bulb)
And the 'Eco' button light is out, again I assume thats a single lamp. the button does work as the 'Auto' disengages.
Re: Onboard phone
« Reply #6 on: 14 February 2009, 14:49:41 »
Yes its the 700.
the switches don't have user changeable bulbs, so you'll need to get soldering iron out
