Author Topic: Newbie owner...big problem please help.electrics?  (Read 2832 times)
ianph
  • Sutton,Surrey
« on: 13 February 2009, 09:13:51 »
Hi,
This is my first post on this site and i have barely owned my auto 2.0gls omega for a week and i think i have caused a self inflicted problem....
I was trying to sort out my car radio and all of a sudden the speedo started going mad jerking up and down and there were a few noises coming from under the bonnet.(car wasnt running).I tried to start it but no luck.
I ripped the radio out and it seemed fine.It wasnt until i drove home that i noticed the car is maxing out at 4500rpm while driving and while revving in neutral.
Does anyone know what i could have done? I know its likely to be something electrical but thats as far as it goes.Want to exhaust all my options before calling a diagnostics expert out!
Thanks so much in advance for any advice given.
Re: Newbie owner...big problem please help.electrics?
« Reply #1 on: 13 February 2009, 09:26:24 »
dis connect the battery for 20 mins, see if it re sets anything...? if you do this you will need to reset windows(hold button in up position when closed) and sun roof(press the hold the dial in each position, open first then closed then tilt)
Always dis con the battery when working on the car anyway, its good practice, and a pain in the arse, but saves situations like this.
Oh, and yours  will need the radio code as well.
« Last Edit: 13 February 2009, 09:27:57 by chrisgixer »
ianph
  • Sutton,Surrey
« Reply #2 on: 13 February 2009, 09:31:03 »
Ok thanks ill try that shortly,hopefully will sort it out.
« Reply #3 on: 13 February 2009, 10:10:08 »
Maybe you've trapped a wire to earth somewhere?  :-/
« Reply #4 on: 13 February 2009, 10:23:53 »
Hi,
Symptons of cam sensor. Paperclip it see if any codes. Look here http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 :y
ianph
  • Sutton,Surrey
« Reply #5 on: 13 February 2009, 10:53:16 »
Tried disconnecting the battery for 20 mins.....no luck still sticking on 4500rpm.
« Reply #6 on: 13 February 2009, 10:55:45 »
As per post. Symptons of cam sensor :)
ianph
  • Sutton,Surrey
« Reply #7 on: 13 February 2009, 11:05:09 »
Cheers Rob.....
Just tried to do paperclip test...nothing on the dash lights up at all.Watched the video and sure im doing it right.?????
ianph
  • Sutton,Surrey
« Reply #8 on: 13 February 2009, 11:06:51 »
Would the cam sensor become faulty directly beacuase of my attempting to fit radio and speedo goi ng crazy etc?
« Reply #9 on: 13 February 2009, 11:16:32 »
Nope. Can you describe the "noises" you heard from under the bonnet :question. Has the EML came on at all on the dash :question
ianph
  • Sutton,Surrey
« Reply #10 on: 13 February 2009, 11:22:22 »
As the speedo was going crazy,shortly pushing the radio back in the slot,it was like a whirring sound under the bonnet.I then tried to start the motor....wouldnt start.Disconnected the radio and the car started fine and i thought all was ok...until i drove it home from work and found the revving problem.
All was defo ok before this as i had given it a bit of a thrash to make sure all was ok.
Which dash light is supposed to flash while doing the paperclip? Nothing on mine at all.
« Reply #11 on: 13 February 2009, 11:27:43 »
Orange one with engine symbol. Ignition on, engine NOT running
« Last Edit: 13 February 2009, 11:28:44 by RobG »
ianph
  • Sutton,Surrey
« Reply #12 on: 13 February 2009, 11:37:12 »
Ok,tried the paper clip again and nothing at all.In fact the only orange light coming up when ignition is turned on is the abs light.(even without paperclip.
Have noticed when paperclip is in the rpm needle starts moving of its own accord.
Cant believe mucking around with a radio could have caused this???
Trying my best to diagnose/fix this myself as im skint after buying the motor!
jonathanh
  • coventry
« Reply #13 on: 13 February 2009, 11:42:19 »
ok so start this methodically.
when you turn the ingintion on you should get three lights: ABS, airbag and engine warning light.  If they all do not come on then the bulbs are broken or deliberately removed.
Step 1 - get new bulbs in: not too bad really, just need to instrument panel out - should be a how to on here
step 2 - flash out the codes and post here/ find out what they are
Step 3 - await the oracles on there to point you in the right direction.
all of the above should cost you a pound or two for bulbs
« Reply #14 on: 13 February 2009, 11:44:55 »
Here`s the link http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
