Author Topic: Wheres the EGR on my TD?  (Read 2705 times)
Arrolman
  • Renfrew,Scotland
« on: 14 February 2009, 17:46:47 »
Hi,
With all the talk of EGR valves on here recently i'd like to give mine a clean, where abouts is it on my TD?
Cheers,
Iain
Looking to win the lottery..........
Omegatoy
  • UK
Re: Wheres the EGR on my TD?
« Reply #1 on: 14 February 2009, 17:52:10 »
throttle body by the black plastic turbo diesel bit :y
Arrolman
  • Renfrew,Scotland
« Reply #2 on: 14 February 2009, 17:59:02 »
Ta very much :y
Iain
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 14 February 2009, 18:42:39 »
Front end of inlet manifold.
Has two small-bore pipes from the underside.
Outer pipe goes to solenoid valve (by power steering reservoir).
Inner vents to atmosphere. Best to lengthen this downwards behind (and below) the radiator. Any oil build-up will then drop to the road, and doesn't get blown around the nearside of the engine bay by the viscous fan.
You'll need to remove the charge air pipe, (embossed 'turbo diesel'), and give this a good clean-out too. Oil build-up in this is usual.
« Reply #4 on: 14 February 2009, 20:07:36 »
Some only have the vac connection, nothing else :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #5 on: 14 February 2009, 20:39:13 »
Yep, mine has only one, but I still have gungy oil dropping onto the coolant hose running to the engine block.
Don't know where that's coming from. :-?
« Reply #6 on: 14 February 2009, 20:48:59 »
ultimately from turbo. leaks from egr.
Omegatoy
  • UK
« Reply #7 on: 14 February 2009, 20:56:37 »
correct
however the lowest point of the system is the intercooler which is where the oil mist condenses and collects mostly, well worth whipping it off and cleaning it  out!!!  :y
« Reply #8 on: 14 February 2009, 21:03:41 »
correct
my intercooler is always absolutely empty :y
Omegatoy
  • UK
« Reply #9 on: 14 February 2009, 21:42:51 »
correct
in that case your turbo is good!!!! which is borne out by the good emission figures on your MOT!!! :y
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« Reply #10 on: 15 February 2009, 08:02:33 »
Where is the intercooler that needs whipping off to clean?
Seth
« Reply #11 on: 15 February 2009, 10:38:53 »
Forward of O/S/F wheel-arch.
Follow the rubber outlet pipe forwards from the turbo.
Wouldn't mind having a look at mine, but not sure how to remove it.
See my post!
« Reply #12 on: 15 February 2009, 12:09:12 »
See my post!
pretty obvious- 2 bolts iirc  :-/
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #13 on: 15 February 2009, 12:38:34 »
Silly question, does a blocked EGR lead to the car running in "Slug" mode from time to time? almost like feeling as though you are driving with the Hand brake on?
As I have this on mine from time to time, which I normally clear by dipping the clutch and revving the engine??  Or am I barking up the wrong tree???
« Reply #14 on: 15 February 2009, 13:09:07 »
Would need to get the fault codes to find out your issue.  Some tractors can be paperclipped, so try that
