Pages: [1] 2 3  All   Go Down
Author Topic: Just fitted new front brake pads but not very hapy  (Read 6361 times)
Miggy24
  • Exeter,Devon
« on: 10 February 2009, 12:26:12 »
Hi all just fitted some new front brake pads.i took the brake fliuld cap off so when i pushed the piston/s in it wouldnt make to much pressure.Anyway after fitting them i started the car up and pumped the brake pedal it got hard but it went down to the floor.I then took out some brake fluild and the brakes got alot harder and better but still went to the floor.Do you think iv got some air in ther brakes
Re: Just fitted new front brake pads but not very hapy
« Reply #1 on: 10 February 2009, 12:29:03 »
How much fluid was in the tank?
You did not need to open it really, just lift the caliper up, and push it in with a large G-Clamp or something, then pop the new pads in.
Miggy24
  • Exeter,Devon
« Reply #2 on: 10 February 2009, 12:46:23 »
well it over filled thats why i took some fluilded out but like i said it did made the brakes alot better but pedal still goes to the floor so i think theres air in the brakes
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 10 February 2009, 12:54:38 »
I've not heard of this happening on an Omega, but have on Astras and Vectras ........
There's a possibility here that you've 'flipped' the seals in the master cylinder, when you retracted the brake caliper piston to fit the new pads. Caused by reversing the flow of the fluid against the seals, and will mean a new master cylinder!
However, try a good bleeding first and see what happens.
Miggy24
  • Exeter,Devon
« Reply #4 on: 10 February 2009, 13:04:05 »
A new master cylinder :o i hope not.I`ll try with bleeding it first
    • 530D M Sport, 330i Coupe
« Reply #5 on: 10 February 2009, 13:23:22 »
You did not need to open it really just lift the caliper up, and push it in with a large G-Clamp or something, then pop the new pads in.
Disagree, by doing that you are forcing fluid backwards, I would open the bleed nipple, attach a pipe then push the piston back which would expel the old fluid in the caliper out rather than backwards.
« Last Edit: 10 February 2009, 13:24:20 by VXL_V6 »
Miggy24
  • Exeter,Devon
« Reply #6 on: 10 February 2009, 14:44:28 »
So do you think its just abit of air.the brakes are good and hard and stop the car quick like they did before just if i push the brake hard it slowly goes to the floor
Iain
« Reply #7 on: 10 February 2009, 14:53:12 »
Did you bleed them? if so make sure the nipples are tight is they are try bleeding them again mate
Miggy24
  • Exeter,Devon
« Reply #8 on: 10 February 2009, 14:54:30 »
No i havent tryed to bleed them yet as im all by myself and no one to lend a hand.well take it to my mates in the next day or 2
« Reply #9 on: 10 February 2009, 14:57:16 »
If the pedal is not spongy but gradually sinks to the floor under prolonged pressure the fluid is leaking past a seal somewhere. Check each of the calipers as you will see fluid leaking from these. If nothing evident it's probably the master cylinder.
I agree it's good practice to open the bleed nipple when retracting the cylinder. The fluid in the cylinder will be manky so may as well get rid of it. I normally flush a bit of fresh fluid through the system using a pressure bleeder whenever I've worked on the brakes both to bleed it and to effect a partial fluid change.
Miggy24
  • Exeter,Devon
« Reply #10 on: 10 February 2009, 15:06:17 »
Thats how the brake pedal feels.Shall i still try giving it a bleed or just get a new master cylinder
« Reply #11 on: 10 February 2009, 15:12:43 »
Right....a litle trick from Astra/Corsa's.
Get a rubber mallet and press the brake pedal right to the floor.
Let go of the brake pedal and as you do, get somebody to wallop the end of the master cylinder with the mallet.
Miggy24
  • Exeter,Devon
« Reply #12 on: 10 February 2009, 15:15:49 »
 :-? what would that do
« Reply #13 on: 10 February 2009, 15:17:26 »
It corrects inverted seals!
Miggy24
  • Exeter,Devon
« Reply #14 on: 10 February 2009, 15:20:59 »
Ohhh i see well i`ll give that a try thanks for that mate :y
Pages: [1] 2 3  All   Go Up
