Author Topic: Is it worth doing the headgasket??  (Read 1597 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 15 February 2009, 10:11:30 »
Just got a 3.2 lump which had an oil cooler failure at 60k.  Just wondering if its worth doing the headgaskets anyway??  Aswell as general top-end overhaul??
Humbugs...
Re: Is it worth doing the headgasket??
« Reply #1 on: 15 February 2009, 10:12:16 »
they are usually very strong, i would say no, just get the oil cooler done.
« Reply #2 on: 15 February 2009, 10:14:41 »
Nope, unless you want them cleaned up and checked out (i.e. stage 1 port and a good clean with new stem seals)
Remember that the 3.2 and 2.6 have steel headgaskets
PaulW
« Reply #3 on: 15 February 2009, 10:18:19 »
Ahh right wasn't aware the 3.2 was a full steel headgasket, should be ok then :)
Only thing which did happen was the oil light flickered on when the cooler dumped the oil into the coolant system, other than that, engine is said to be fine & no knocks, noises or smoke.
It was owned by a women since new  ;D
Humbugs...
« Reply #4 on: 15 February 2009, 10:19:15 »
As you would expect as the oil cooler is on the high pressure side so the oil pressure would suddenly drop
PaulW
« Reply #5 on: 15 February 2009, 10:22:41 »
Fair enough :)  I'll just crack on getting it sorted for fitting to the Omega!  No doubt I'll get some funny looks from the stealers when I give them the engine number & ask for bits relating to the Omega as its stamped Z32SE on the block  ;D ;D
Humbugs...
« Reply #6 on: 15 February 2009, 10:23:38 »
Why use the dealers......
PaulW
« Reply #7 on: 15 February 2009, 10:27:17 »
Can get things at a staff discount rate or less on other things now, so not just TC or usual 10% trade.
Can do me full oilcooler kit for £60 inc governments tea fund, so not too bad I think for genuine.  Plus going to get cambelt kit for it too.
Everything else I'm just going to steal from Daz tomorrow  ;D
« Last Edit: 15 February 2009, 10:28:01 by PaulW »
Humbugs...
Martin_1962
« Reply #8 on: 15 February 2009, 10:49:37 »
2001 yes
2002 no
2001 engines had crap valve stem seals - like mine >:(
PaulW
« Reply #9 on: 15 February 2009, 11:18:28 »
2001 yes
2002 no
This is from a 53 Vectra :)
Humbugs...
Martin_1962
« Reply #10 on: 15 February 2009, 13:33:27 »
2001 yes
2002 no
Should be fine then
« Reply #11 on: 15 February 2009, 18:05:33 »
:oAre you sure
PaulW
« Reply #12 on: 15 February 2009, 18:10:55 »
:oAre you sure
Yes but its not the 'local' stealer as have to travel to Ellesmere Port for it (friends dad is parts manager there) as its been on the shelf there for about 8 months and they just want rid ;D
Humbugs...
