Author Topic: sweeky rear disk  (Read 1350 times)
Miggy24
  • Exeter,Devon
sweeky rear disk
« on: 15 February 2009, 14:35:17 »
Hi all over the last 3-4 days there has been a sweek coming from the n/s/r disk.I have had alook and i can see that there is abit of a lip and the brake pads are rubbing on them.does this mean that the rear dick is worn
hotel21
  • The Kingdom of Fife
Re: sweeky rear disk
« Reply #1 on: 15 February 2009, 14:44:58 »
As soon as you use the brakes they will be 'worn' to an extent and their design puts the pads in close proximity to the disc.
Suggest you overhall the brakes, following a guide on here, which will clean out crud and allow the pads to move freely.  If you put a slight chamfer on the edge of the pads closest to the ridge that may reduce the squeek somewhat.
Miggy24
  • Exeter,Devon
« Reply #2 on: 15 February 2009, 16:03:52 »
well the mot tester did say that the disk is very worn.I had a quick look its all nice and clean in there took the pads out gave them a clean with a wire brush and still the same
hotel21
« Reply #3 on: 15 February 2009, 16:27:23 »
In that case, change them??   :D
« Reply #4 on: 15 February 2009, 16:41:16 »
The MOT tester said that about SWMBO's Astra's brake discs about 3 years back. 'Worn to minimum' was his remark ........ the car has since passed at the same test station and at A N OTher with the same discs.  :-/
Measure them. There's 150 000 miles on my car and I don't believe the rear discs (or fronts) have ever been replaced. Rear discs don't tend to wear out as most of the braking is obviously done at the front.
« Last Edit: 15 February 2009, 16:43:33 by Andy_B »
hotel21
« Reply #5 on: 15 February 2009, 17:00:35 »
....... Rear discs don't tend to wear out as most of the braking is obviously done at the front.
Dont neccessarily agree.  Yes, the fronts do carry more effect due to weight transfer etc however the rears also have a part to play.  They contribute quite a substantial proportion to the overall braking effect of a vehicle - you see a substantial difference when a rear setup is working correctly.
Likewise, the pads can and do catch a lot of crud in their mountings and do stick.  This does result in drag and wear on the brake face as we all know.  Its whether you have the technical ability or knowledge to ascertain how much wear is excessive thats in question.
Ultimately, its upto the individual if they wish to heed advice of others or not...
« Last Edit: 15 February 2009, 17:01:15 by hotel21 »
« Reply #6 on: 15 February 2009, 17:05:36 »
I'll have to agree with you again!  ;D
Just commenting that it's easy for the tester to say 'discs are worn beyond limits' without measuring them.  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #7 on: 15 February 2009, 19:08:04 »
Don't mess around - fit new discs and pads to the rears.
Best pads to use are genuine Vx or EBC.
No problems after 000's of miles either.
Miggy24
  • Exeter,Devon
« Reply #8 on: 15 February 2009, 19:12:25 »
How much are new rear discs
