Author Topic: Headlight/Tail light Warning Question  (Read 1907 times)
johndm1957
  • Bedford
« on: 12 February 2009, 07:29:52 »
Started to get a headlight/tail light warning, but everything is working!
Any ideas guys?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Headlight/Tail light Warning Question
« Reply #1 on: 12 February 2009, 08:10:41 »
Check the tail lights in the bootlid mate  :y
« Reply #2 on: 12 February 2009, 09:15:10 »
What Loo-Knee says, 2 tail lamps plus 2 stop/tail lamps! Failing that use 4 new quality lamps.
johndm1957
  • Bedford
« Reply #3 on: 12 February 2009, 11:27:02 »
Does my 2003 Elite have tails in the bootlid then.......?
I don't recall them ever working!!
« Reply #4 on: 12 February 2009, 11:32:15 »
Are they not the rear fogs?
johndm1957
  • Bedford
« Reply #5 on: 12 February 2009, 11:48:46 »
I'm sure mine has only two outer tail lights, and the bootlids are fogs.(my older '97 had four tail lights).
Maybe its a tail light working intermittantly, and every time I look its back on.?
Warning popped up 4 times on the way to work today
« Reply #6 on: 12 February 2009, 11:52:12 »
I can't say for the face lift cars .... take the lamp holder out & have a look.  ;) but I thought all Omegas, old & new shape, had a tail & a stop/tail on each side. :-/
johndm1957
  • Bedford
« Reply #7 on: 12 February 2009, 20:27:24 »
Tail/brake on outer clusters only, boot clusters are fogs.
Nothing seems loose, might just try a couple of new lamps tomorrow..
« Last Edit: 12 February 2009, 20:28:08 by johndm1957 »
« Reply #8 on: 12 February 2009, 20:55:24 »
All saloons only have fogs and reverse in bootlid.
There are 4 tail bulbs though, but all in outer cluster.
Don't think numberplate light monitored.
Try better quality bulbs if it persists
johndm1957
  • Bedford
« Reply #9 on: 13 February 2009, 18:11:56 »
Outer Clusters are ONE tail/brake, and ONE indicator.
New bulbs seem to have cured it.... :y
Thought I'd change the number plate lamp too, housing looked damaged when removed........
Both pins inside fell out when I removed the lamp, as part of the housing has previously broken off. Threw into bin in disgust, then wish I had'nt when my local Mr Vauxhall charged me £20 for a new one.
 :o
« Last Edit: 13 February 2009, 18:13:14 by johndm1957 »
« Reply #10 on: 13 February 2009, 19:37:06 »
 :o
Plenty of breakers on this site ;)
johndm1957
  • Bedford
« Reply #11 on: 15 February 2009, 21:04:31 »
Warning back again despite new bulbs...... :'(
Also noticed last night my fuel gauge dropped to zero for a few mins for no apparant reason...low fuel flashing too, all on a FULL tank.
Another thread suggested an earth problem. Removed plastic trim around boot catch, removed and cleaned the connections.
(the ones to the passenger side with the 10mm nut...is this the correct and/or only earth back there?)
Will see what happens tomorrow!
« Last Edit: 15 February 2009, 21:05:29 by johndm1957 »
MutantCav
  • Gainsborough
« Reply #12 on: 15 February 2009, 22:00:59 »
Indeed and facelifts are being broken more and more now...got 2 facelift MV6 saloons here :)
