Author Topic: Converting FWD V6 to RWD Config??  (Read 3228 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Converting FWD V6 to RWD Config??
« Reply #15 on: 15 February 2009, 21:57:20 »
I should be able to source most of those bits easy enough :)
I guess then the thermostat housing & pipe which comes out the front is the same then??
Humbugs...
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #16 on: 16 February 2009, 12:27:13 »
parts required:
Sump(s)
Oil pick up
Engine mounts
Inlet and exhaust manifolds complete
Water transfer pipe.
Engine wiring loom
Dipstick tube and dipstick
Flexplate and torque convertor
All the RWD engine ancillaries (starter alternator etc)
Basically we sat both engines together and swapped the lot over bit by bit
 Am I right in thinking most of these can be taken from the 2.6 in (ish) my car? If so, I may have just sorted my engine supply problem...
PaulW
« Reply #17 on: 16 February 2009, 14:07:58 »
parts required:
Sump(s)
Oil pick up
Engine mounts
Engine wiring loom
Well I've got most of these from a 3ltr so can't see why a 2.6 would be any different if your doing a facelift one :)
Humbugs...
