Author Topic: Converting FWD V6 to RWD Config??  (Read 3212 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 13 February 2009, 21:03:01 »
3.2 from say a FWD Vectra...
What would be needed (parts) to convert it to RWD??
I've already got plenum, inlet, bagpipes, ecu, loom...
Guessing also:
Sump pan
Metal coolant hose (from rear of engine)
Cam covers
Flywheel & torque converters (fitting to an automatic)
Anything else??
« Last Edit: 13 February 2009, 21:03:30 by PaulW »
Humbugs...
iainb
  • West Midlands
Re: Converting FWD V6 to RWD Config??
« Reply #1 on: 13 February 2009, 22:32:07 »
Mega bucks for the chassis conversion.
« Reply #2 on: 13 February 2009, 22:41:46 »
i think he means putting a 3.2 from a veccy into an Omega, so no need for chassis mods
« Reply #3 on: 13 February 2009, 22:42:12 »
Paul speak to JayW, he put a FWD 2.6 from a Veccy in his Omega...
PaulW
« Reply #4 on: 13 February 2009, 22:45:36 »
Yup :) Hence why saying convert a FWD from a Vectra to RWD config for the Omega :)
I'll PM Jay W  :y
Humbugs...
iainb
  • West Midlands
« Reply #5 on: 13 February 2009, 22:47:56 »
Sorry :'(
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 13 February 2009, 23:12:07 »
Guessing also:
Sump pan
Cam covers
Anything else??
just about what you have listed there paul  :y
Omegatoy
  • UK
« Reply #7 on: 14 February 2009, 18:01:15 »
surely the oil pick up  pipe will need changing as well???
Ian_D
  • York
« Reply #8 on: 14 February 2009, 18:13:31 »
I'll PM Jay W  :y
I thought you meant converting a Vectra to RWD! - Can be done, just costs a lot, and takes a lot of time, and costs a lot, and needs a lot of effort, oh and costs a lot!  ;D
Like Omegatoy says, I think the oil pickups are different too IIRC.  :y
« Last Edit: 14 February 2009, 18:14:44 by Ian_D »
[size=12]
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #9 on: 14 February 2009, 18:29:31 »
This is something I'd thought vaguely about, I think given the cost of getting the separate parts, you (and me) are better off waiting for a 3.2 Omega engine to come along...
PaulW
« Reply #10 on: 14 February 2009, 18:33:16 »
True  ;D tbh though most parts I have, and ones I don't are easy enough to get from breakers cheap enough :)
Humbugs...
PaulW
« Reply #11 on: 14 February 2009, 18:58:53 »
Well I now have a 3.2 engine from a Vectra  ;D
Humbugs...
markey mark
« Reply #12 on: 14 February 2009, 19:59:04 »
how much paul ??? :y
PaulW
« Reply #13 on: 14 February 2009, 20:03:34 »
PM sent  ;D
Humbugs...
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #14 on: 15 February 2009, 17:53:32 »
parts required:
Sump(s)
Oil pick up
Engine mounts
Inlet and exhaust manifolds complete
Water transfer pipe.
Engine wiring loom
Dipstick tube and dipstick
Flexplate and torque convertor
All the RWD engine ancillaries (starter alternator etc)
Basically we sat both engines together and swapped the lot over bit by bit
