Author Topic: Facelift Door Cards  (Read 1155 times)
Iain
Facelift Door Cards
« on: 16 February 2009, 20:28:08 »
My front doors interior panels are loose,the passenger one is the worst..i have read the 'how to' but wondered if mine are damaged?
The passenger side pulls out at the top....
If you pull it it moves out from the top to roughly where the wood panel strip is.....is there a common problem here,i.e is it bust somewhere,or is it a case of not been put on properly,or do they work themselves loose??
Just wanted to check first before i go pulling it off....
Can someone also tell me how the plastic lock cover is removed..........
Without breaking it ;D
unlucky alf
  • worksop, notts
Re: Facelift Door Cards
« Reply #1 on: 16 February 2009, 20:39:27 »
if its anything like the prefacelift then the door card has a plastic channel glued to the back which hooks over the top lip of the door, a couple of mine came adrift so i had to evo-stick them back on then they stayed put :y :y
Iain
« Reply #2 on: 16 February 2009, 20:44:20 »
Thanks Alf,i guess im better just taking them off and seeing whats going on behind there??
« Last Edit: 16 February 2009, 20:44:50 by Iain »
« Reply #3 on: 16 February 2009, 20:53:22 »
Same as mine. I 'No nailed' mine back on.  ;)
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #4 on: 16 February 2009, 21:50:32 »
Link to how 2:-
http://www.omegaowners.com/forum/YaBB.pl?num=1152953579
Which also details how to fix the channel back on
Iain
« Reply #5 on: 16 February 2009, 22:09:04 »
Cheers Al...... :y
i did read this earlier,but this time it has pics...... ;D didnt last time....
