Author Topic: Rocker gasket Leak Missfire  (Read 1186 times)
martctb
« on: 17 February 2009, 13:24:24 »
Help as i still have a problem with my omega 2001 2.6
1. Firstly Oil cooler went changed that
2. Secondly rocket gasket went and took coil pack with it changed that
3. Changed other rocker gasket
The car ran fine for 5 miles then first the emmmision light came and then swopped itself for the engine fault light also rocket torqued down to correct Nm put still seems to leak any ideas.
Re: Rocker gasket Leak Missfire
« Reply #1 on: 17 February 2009, 13:32:59 »
Did you clean the breathers?
martctb
« Reply #2 on: 17 February 2009, 13:36:58 »
Yes breathers all cleaned when i did the gaskets
Welung666
« Reply #3 on: 17 February 2009, 13:38:58 »
Are they genuine VX gaskets and did you use the correct black sealant?
