Author Topic: Size of the xenon headlight projector lense  (Read 1223 times)
gsizoli
  • Hungary
« on: 16 February 2009, 17:21:48 »
Hi!
I need a little help.I have a facelift Omega MY2000, Y reg.
I have problems with my factory fitted xenon headlights, both lamps are HELLA, with D2S xenon. Unfortunately the light of the lamp is weak.I've already replaced the xenon bulbs but theres
was no relevant change. So I took out and checked them, and it seems the projectors reflexion part are nok, and as I see there are fernel lenses in the lamp, so I cant see through on the lenses....
I want to buy new clear lenses and i need information about the size of the lenses, diameter and height, and if it's possible a picture also would be great.  ;)
Perhaps there are a broken xenon headlight to somebody at home where the lenses are OK and can measure for me and send a picture.
It would be a huge help for me, because I could order the lenses immediately, and when I started to work on a headlight the lenses will be here.
Br
Zoli
Re: Size of the xenon headlight projector lense
« Reply #1 on: 16 February 2009, 18:49:20 »
Are both equally bad?
gsizoli
  • Hungary
« Reply #2 on: 17 February 2009, 08:50:16 »
Yes. Unfortunately both are weak. Is it ok If I can't see through on the lenses?It has whity colour...
« Reply #3 on: 17 February 2009, 10:22:38 »
Lenses need to be clear  -  whiteness or opacity will reduce light output
gsizoli
  • Hungary
« Reply #4 on: 17 February 2009, 14:33:25 »
OK.I will try to open the headlight and clean it.I hope it will help.
