Author Topic: Car Cut out  (Read 1937 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Car Cut out
« on: 17 February 2009, 10:50:06 »
Hi there .... my car started fine as usual this morning then as soon as i went to drive it cut out  :-/ .... seemed to take a bit longer to fire up after but was fine after it started... this is the second time this has happened in as many days .... there are no codes stored ... no oil in wells , anything else i can check or is this a symptom of crank or cam sensor .   :y
hotel21
  • The Kingdom of Fife
Re: Car Cut out
« Reply #1 on: 17 February 2009, 10:56:36 »
I'm heading to St Andrews today, can pop round?  PM me a mobile number and we can sort something out.... ;)
Proz
Re: Car Cut out
« Reply #2 on: 17 February 2009, 10:57:08 »
ok   will do  :y
Proz
Re: Car Cut out
« Reply #3 on: 17 February 2009, 10:59:14 »
Pm'd  :y
Christian
  • Shropshire
Re: Car Cut out
« Reply #4 on: 17 February 2009, 11:35:54 »
Can blocked breathers cause this issue also?  :)
Nope i dont doo Sheep!
Proz
Re: Car Cut out
« Reply #5 on: 17 February 2009, 11:41:15 »
Strangely enough i actually have a gasket set for this in the boot ... its not leaking at the moment but i was going to do them as a precautionary measure sometime this week and do the cam gasket as well .... :y
omega6
  • Midlands
Re: Car Cut out
« Reply #6 on: 17 February 2009, 15:46:29 »
had a similar problem on mine a couple years years ago, would be difficult to start, left it for a while go back and satrted ok, cuts out after driven a few miles. changed crank sensor, car  has been dandy ever since :-X
