Author Topic: How to Correct Oversteer?  (Read 4085 times)
Re: How to Correct Oversteer?
« Reply #15 on: 13 November 2007, 09:54:02 »
have you turned the TC off ??? if so TURN IT BACK ON !!
TC only works by detecting slip of either of the rear wheels by speed differential. It doesn't detect nor correct oversteer. If you throw the car into a corner with far too much power on the inside rear wheel will unload and spin straight away and the TC will indeed cut power before an oversteer develops.  In fact, in this instance, the spinning inside rear wheel does a good job of limiting the torque to the outside wheel and will probably prevent the whole back end braking away unless you're "doing a clarkson" with the throttle pedal or you have a limited slip diff.
With gentle acceleration and cornering, perhaps on a slippery surface, the back end can get quite wayward without a large speed differential between the two back wheels (since they have both run out of traction - hence the slide) and TC will be none the wiser.
TC also backs off the power rather quickly IMHO, although only with quite a bit of power on in the first place. As mentioned, a rapid lift-off is just as bad has putting too much power on in the first place. Smoothness in your response and not panicking is key. As Hotel21 says, that comes from practicing at Tesco's car park a skid pan.
.. Just don't ever think you can rely on TC to get / keep you out of trouble.
106rallye
  • Glasgow
« Reply #16 on: 13 November 2007, 12:45:51 »
I'll be the first to admit that I drive my car hard.  But, as the saying goes..... 'power is nothing without control.'
i don’t drive my car too hard at the moment but i have it sideways all the time lol if its wet its hard (mentally more than physically  ::) to keep it in a straight line!
its handy to practice as when it happens and your not expecting it you know what to do without thinking. saved me a few times even in my fwd car when, if i didn’t know what i was doing i would of crashed (and died one of the occasions).
don’t practice where other people could get injured though, spinning is almost guaranteed when your learning, even after you have an idea of whet your doing! lol
sideways is the way forward!
Paul M
  • Edinburgh
« Reply #17 on: 13 November 2007, 13:18:51 »
Agreed -- it's not stability control, so it doesn't monitor things like the yaw and pitch of the body, nor the steering input. All it will do is try to prevent the rear wheels spinning under power, and it's pretty crude at that IMO. Personally I find it a hindrance and much prefer it off. My right foot serves as a much better traction control device ;)
I think your main problem is the cheapy tyres. I had Kwik Fit specials on mine when I bought it, and it was a nightmare to drive in the wet. I remember coming off a roundabout once and the back end stepped out, I ended up drifting it for about 30 or 40 metres trying to gently bring it back into line, and that was me driving sedately :o. It's one thing enjoying controlled drifting at the right time/place, it's quite another having to deal with it every time you apply more than 10% throttle! I done my utmost to wear those tyres out (including copious amounts of donuts in the Knockhill car park :D) then replaced them with Michelin Pilots -- much more expensive, but cheaper than writing your car off!
BTW as mentioned by TB and some others, snapping the throttle shut is the instinctive reaction that will be fine at small slide angles and lower speeds, but I wouldn't recommend it if the car gets really out of line. You can then experience lift-off oversteer due to the weight shift, where the fronts suddenly grip much  more than the rears, meaning that even though the rears are no longer being asked to grip in anything more than the lateral direction, the momentum and lack of weight can cause the rear to spin round past the point you can catch it. A gentle reduction of power while counter-steering is the best approach, and it should tuck back in nice and smoothly.
« Reply #18 on: 13 November 2007, 13:41:19 »
.....that and the fact that you then have engine breaking at the back.
The Barge Captain
« Reply #19 on: 13 November 2007, 15:40:26 »
I crashed a mate's Shogun last week when it all went a slip sliding away on a country road. Started to slide on a mild LH bend , tried to get it back then it went the other way, spun 180 and ended up in a hedge.   :-[
Cost him £400 in T cut to put it right.
It was raining slightly and the darn car was twitchy as hell.  I blame the tyres as i've never had a problem like it before in any other car on that road.  Horrible thing to drive.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #20 on: 13 November 2007, 19:51:23 »
Even with 4WD? :o
106rallye
  • Glasgow
« Reply #21 on: 13 November 2007, 20:22:48 »
Cost him £400.
 :o he had to pay when u crashed it? thats a bit shit.
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #22 on: 13 November 2007, 23:41:14 »
 :o
Shogun's have got a really really bad turning circle, crap MPG, have serious engine problems if not maintained to a sky high standard... I'd still have the 2.8TD wideboy shape though.  :y
Paul M
  • Edinburgh
« Reply #23 on: 14 November 2007, 13:32:12 »
Probably doesn't help that it has a centre of gravity almost as high as the moon, so once it starts to get out of shape every correction creates a pendulum effect that is very difficult to keep under control.
Chelsea tractors should stick to the fields where their poor roadholding is unlikely to be an issue!
106rallye
  • Glasgow
« Reply #24 on: 14 November 2007, 13:47:46 »
Omega or Shogun?
« Reply #25 on: 14 November 2007, 18:34:55 »
Stay safe is the key, and also (try) and stay legal ;)
I remember hitting a bend way to fast in my facelift.. I had maria in the car too  ::) .. it handled it surprisingly well, but I had to correct the rear end once or twice..
Of course, I looked and acted like I was fuly in control at all times  ;D
Those those somewhat suspect tyres you have on the rear ::)
Page created in 0.025 seconds with 16 queries.
