Author Topic: Bloody Clickity Clack........  (Read 6621 times)
« on: 08 January 2009, 15:04:36 »
.......that is driving me mad every time I open or close my drivers door! >:( >:( >:(
After obtaining a new special "bushing" (Vx part no. 090462823) well before Christmas, I have at last fitted it.  However, the noise is now worse and sounds as though the door is going to blow apart!
I have taken off the door card and tried to reach the internal part of the 'door stop' mechanism, without any great success, but have at least greased it all up, but still it is going .....clickity clack.......clickity clack........clickity clack....grrrrrrrrrrrrrr >:( >:( >:( >:(
Any ideas please?? :-? :-? :-?
« Last Edit: 08 January 2009, 15:05:45 by Lizzie_Zoom »
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Bloody Clickity Clack........
« Reply #1 on: 08 January 2009, 15:09:59 »
hinges maybe not sure but can imagine your pain >:(
« Reply #2 on: 08 January 2009, 15:21:40 »
Thanks HGV :y :y, but it is not the hinges but that silly sliding 'door stop' for sure that seems to be "twanging" the panels! >:(
jjleonard
  • stevenage
« Reply #3 on: 08 January 2009, 15:37:15 »
Is this the door check strap issue? my drivers door sounds like a bleeding wooden drawbridge when I open it. I was planning to do the check strap but it's just too flaming cold at the moment.
« Reply #4 on: 08 January 2009, 15:40:08 »
Yes Leonard, you are using the correct word for it; I call it a bloody stupid thingy >:( :D :D ;)
What do you think we can do about it?
I know eventually the mountings are going to 'pop' if I don't do something, and I am certainly going to 'flip' big time rather thing! >:(
« Reply #5 on: 08 January 2009, 15:41:13 »
Are the bolts that secure the check strap to the door tight?
Any sign of damage to the metal section where the bolts are on the door?
jjleonard
  • stevenage
« Reply #6 on: 08 January 2009, 15:43:11 »
Right now Lizzie, I have no idea. I'm just going to get the bits, follow the guide and hope it all works when I do it. As far as I can see the check strap just stops the door swinging past the hinge stop when it's open - perhaps you might be better off with a sturdy bit of string when the check strap finally gives in!  :y
« Reply #7 on: 08 January 2009, 16:03:31 »
Yes thanks Mark, all bolts have been tightened, and there is no external sign of damage to the metal panels; the fixing plate on the main pillar is riveted and at the moment sound. 8-) ;)
« Reply #8 on: 08 January 2009, 16:05:32 »
That sound like a good idea Leonard, but perhaps leather (which they once were in early cars) straps would be better? :-?
benbrunt
  • Oldham
« Reply #9 on: 08 January 2009, 16:31:55 »
Or just parking facing uphill if it snaps  :D
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
« Reply #10 on: 08 January 2009, 16:34:55 »
 ;D ;D ;D ;D ;D ;D ;)
Omega man 2
« Reply #11 on: 08 January 2009, 16:37:53 »
My drivers door is very noisy atm. And I don't know how the straps work. Is there bushings that have to be changed? If so where are they?
« Reply #12 on: 08 January 2009, 17:00:43 »
Mine's the same. Keep meaning to get a new check strap as the bush was replaced recently. Will probably fit the reinforcement kit while I'm at it, and change the central locking motor,.....  ::)
benbrunt
  • Oldham
« Reply #13 on: 08 January 2009, 17:00:44 »
Previous Astra did it, Omega sounds just the same, few Astras at work do it too, have oiled it but to no avail - I'll add it to the list of things to do, pretty much at the bottom of the list, so should be done by 2012 ::)
« Reply #14 on: 08 January 2009, 17:02:02 »
Pages: [1] 2 3 4  All   Go Up
