Author Topic: Fitting an estate towbar  (Read 1545 times)
Miggy24
  • Exeter,Devon
« on: 17 February 2009, 15:40:59 »
Hi guys just a quick one really.When i drill the holes in the floor do i drill then to the right size for the bolts and feed the spacers under or drill them to size for the spacers to fit in.
Miggy24
  • Exeter,Devon
Re: Fitting an estate towbar
« Reply #1 on: 17 February 2009, 17:15:29 »
Oh yeah one more thing would it be helpful if i weld the heads on the bolts so its easyer to do the bolts up as i dont have long arms lol
« Reply #2 on: 17 February 2009, 17:18:09 »
http://www.catalogue.bosal.com/pdf/pdf_mi/019892.pdf
Does this help?
I wouldn't weld the bolt heads up, you need an assistant in the boot with a spanner. I managed to just wedge a spanner in place to hold them.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 17 February 2009, 19:29:35 »
If you dont have an Assistant, Stretch some Amalgamating Tape (TV / Sat Shop) arround the bottom half of the bolt head and washer, it will do up a treat. Gets me out of trouble on all sorts of jobs.  :y
« Last Edit: 17 February 2009, 19:37:28 by zirk »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 17 February 2009, 19:42:45 »
Drill the holes to the size of the spacers then drop the spacers into the holes. Large washers go under the bolt head and then put the bolt down through the spacers and out the bottom and nuts with more washers go underneath.
Jaguar XJ6
Miggy24
  • Exeter,Devon
« Reply #5 on: 17 February 2009, 20:27:15 »
Ok well i`ll give it ago if not a`ll just weld the bolt heads :y
MutantCav
  • Gainsborough
« Reply #6 on: 17 February 2009, 20:32:58 »
Stick a spanner on the bolt head, gently rotate the nut underneath until the spanner wedges against the chassis holding the bolt in place for you to do up the nut  :y
« Reply #7 on: 17 February 2009, 21:37:39 »
I've only ever fitted a saloon's towbar, but on a saloon you're only ever drilling clearance holes for the 10mm? 12mm? bolts. The O/D of the spacers of around 25 mm is already in the underside of the chassis leg and all the spacers are for is so that you're tightening up to the boot floor.
MutantCav
  • Gainsborough
« Reply #8 on: 17 February 2009, 21:43:16 »
When I fitted my old estate one it was 10mm drill into the pre marked positions in the boot...
Miggy24
  • Exeter,Devon
« Reply #9 on: 17 February 2009, 21:47:28 »
I think i`ll be alright fitting the towbar its the wiring up i dont like lol but i should be fine :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #10 on: 17 February 2009, 21:47:37 »
The towbars I have seen have flanges to hold the bolt head whilst you are underneath tightening the nuts up :y
MutantCav
  • Gainsborough
« Reply #11 on: 17 February 2009, 21:48:54 »
The saloon ones with the plate on the boot floor inside do...estate ones dont...
Miggy24
  • Exeter,Devon
« Reply #12 on: 18 February 2009, 17:18:12 »
Fitted the towbar 2day was really easy to fit to be honest only prob i had was getting the nuts of the exhaust heat shild.Got it all wired up 2 but cant see if they work as dont have anything to test it too :y
Page created in 0.208 seconds with 16 queries.
