Pages: 1 [2] 3  All   Go Down
Author Topic: Black Coolant!  (Read 6134 times)
Re: Black Coolant!
« Reply #15 on: 17 February 2009, 18:31:54 »
Flush some bleach through or run it with bleach in? How much bleach?
 :-/ Not sure, a cup full perhaps. I'd run it around the system and take it spin round the block, and then drop it and go from there.  :y
markey mark
  • SLady bitshorpe north lincs
Re: Black Coolant!
« Reply #16 on: 17 February 2009, 18:31:56 »
run it with a bit in it ! or 1/4 litre of jizer for a couple of hours  :y
djdaveyp85
  • Halifax, West Yorkshire
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #17 on: 17 February 2009, 18:36:27 »
Thanks guys! Think i'll do an oil and filter change as well this weekend its been about 3000 miles since i had the o/c changed. Did timing belt and hbv at same time.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Black Coolant!
« Reply #18 on: 17 February 2009, 18:43:34 »
1 LTR OF LOW FOAM WASHING LIQUID IN THE COOLING SYSTEM AND TAKE IT FOR A BLAST FOR 20 MILE AND THEN FLUSH THE SYSTEM ABOUT 5/6 TIMES. soory for the caps lock, i was,nt shouting HONEST.
Jaguar XJ6
djdaveyp85
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #19 on: 17 February 2009, 18:48:47 »
Also thought i'd mention that since i've had the car back the economy isn't as good! ABout 28mpg average where it was 32 before! But everytime i fill it up i get more out of the tank so seems to be getting progressively better!?!
It sometimes takes a while to idle after i rev it as well?
ffcgary1
  • Mitcham,Surrey.
Re: Black Coolant!
« Reply #20 on: 17 February 2009, 18:52:41 »
Poor idle is normally the icv and or an air leak somewhere, make sure that when the oil cooler was replaced that the garage did not forget to put a vac hose on or split one when they refitted it. :y
Jaguar XJ6
vauxfan2k
  • Western Isles
Re: Black Coolant!
« Reply #21 on: 17 February 2009, 18:58:01 »
Mythbusters claim that out of all the myths (coin in the carb, sugar in the fuel etc etc) bleach is the only thing that will KILL an engine, so I dont recommend using it. Some fairly liquid in the expansion tank and run it for a bit, then flush out with hose at low pressure.
Re: Black Coolant!
« Reply #22 on: 17 February 2009, 19:37:29 »
 bleach is the only thing that will KILL an engine, so I dont recommend using it.  .......
HTF is that supposed to happen?  :-?  :-?  :-?
The bleach is only in for a short time to break up the oil ......
« Last Edit: 17 February 2009, 19:38:15 by Andy_B »
Re: Black Coolant!
« Reply #23 on: 17 February 2009, 19:42:50 »
Bleach and Aluminium do not mix at all well ... now how much aluminium is actually in the alloy the engine is made from I don't know ....  but  wouldn't risk it ..
Simple explanation .. google for a complex one if you wish ..
http://www.newton.dep.anl.gov/askasci/chem03/chem03218.htm
djdaveyp85
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #24 on: 17 February 2009, 19:47:01 »
Right! I've done some further investigation! And i've completely flushed it. Its putting oil in the water very slowly as i'm getting dark brown fluid coming straight back into the header tank in little bubbles! Just like was happening before but much slower. So i'm quite confident the rip-off merchant b**t*** who did the job hasn't done it properly as well as charging me £600 labour when i supplied every single part myself! Do I have a leg to stand on in terms of a refund? As I have meticulously taken care of it since i had it back so there is no reason for it to fail!?
I have also found an air leak on both sides of the plastic thingy with the vx badge on it in the middle of the plenum!
I have to say I'm quite p*ssed off. And whilst you guys on here have been an absolute gem of a help, the t**t who fixed my car hasn't!
I really suspect that the oil cooler is leaking again! Does anybody have any ideas?
Re: Black Coolant!
« Reply #25 on: 17 February 2009, 20:20:00 »
Well, you should  give him a chance rectify it in the normal process but i dont think i would want him working on the car at all now.
 I dont purpose you paid by card by any chance?  That price is steep with parts included.
 Diy is the norm on here mate. There is a guide and plenty of knowledge, may well be members near by to help? Have done this job myself so its doable.
Just depends what you find when your in there.
djdaveyp85
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #26 on: 17 February 2009, 20:22:58 »
No it was cash! I had to to barter him down from the £800 he originally wanted to charge me!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Black Coolant!
« Reply #27 on: 17 February 2009, 21:50:31 »
I have not long had my oil cooler done! (Got car back on 5th January!)
Since i had it back i've been flushing the coolant system out weekly and i've just checked it today when i got home from work and the coolant is black! No the chocolate colour it was when had my oil cooler done. I have noticed my engin ehas been sounding a little bit spluttery recently as well! I'm really worried as i've spend nearly £1000 on it so far!
What could this be?
Take it back to the garage you had it done
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Black Coolant!
« Reply #28 on: 17 February 2009, 21:52:33 »
You got the parts? where did you get them from?
MutantCav
  • Gainsborough
Re: Black Coolant!
« Reply #29 on: 17 February 2009, 22:00:12 »
Normal oil cooler price would be £300 including the oil cooler...especially if your flushing out the system yourself anyway...
Have a pair of facelift washer jets here mate in white...
« Last Edit: 17 February 2009, 22:05:16 by ShieldOfSteel »
Pages: 1 [2] 3  All   Go Up
