Pages: 1 2 [3]  All   Go Down
Author Topic: Black Coolant!  (Read 6095 times)
djdaveyp85
  • Halifax, West Yorkshire
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #30 on: 18 February 2009, 08:31:55 »
This is the oil cooler i bought here http://cgi.ebay.co.uk/Vauxhall-Oil-Cooler-93176626-Omega-Signum-Cavalier_W0QQitemZ190286282129QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item190286282129&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
When it arrived it was a genuine gm one and i also picked the sealant up from vx for it. The guy who repaired it order the rubber bits for it and i paid him for that. So i don't think that i bought a naf one. The one that came off was  the same design but had a massive corrosion hole in it.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Black Coolant!
« Reply #31 on: 18 February 2009, 09:22:32 »
It just seems very strange that a new oil cooler has been fitted and yet it is leaking so soon... are you sure he has changed the bloody thing???
I am glad someone else doesn't think you should put bleach in your coolant.... I and several others on the forum have used Forte Coolant System Flush, and it really does the job well, costs around £10 for a bottle.
Personally wouldn't buy anything like that of ebay for this reason really had a coulpe of things go wrong then struggle to get your money back...
Welung666
Re: Black Coolant!
« Reply #32 on: 18 February 2009, 09:24:54 »
I use the holts 2 part radflush, great stuff and around a fiver from your local motor factors :y
djdaveyp85
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #33 on: 18 February 2009, 17:52:09 »
The oil cooler has a one year guarantee for failures. The shop i bought it off is a shop but he also trades on ebay. NIce guy and good prices. I thinking that when the "mechanic" ordered the seals etc for it he may have ordered cheap ones! Checked again today and i have a layel of oil on top of the water in my coolant bottle. Is i possible that anything around the oil cooler can leak and maybe i needed more than an oil cooler in the first place?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Black Coolant!
« Reply #34 on: 18 February 2009, 18:20:23 »
Right lets start again from the top guys,
You need to flush the system again with detergent to break down any oil in the system, see my previous post , then you MAY have to flush and keep flushing for a while yet, so dont just assume that it has failed again so soon.
It is the bane of all v6,s that when the oil cooler lets go you have to spend more time flushing than repairing the bloody thing. You can keep flushing with clear water untill the system stays clean then and only then drain and add 50% pink coolant. I repaired the oil cooler on a vectra v6 and found that the oil was still in the coolant header tank and i could just not get some out so ended up replacing the tank with a new one, improvments were seen straight away.SO FLUSH FLUSH FLUSH AND FLUSH AGAIN. Good Luck.
 :D
Jaguar XJ6
Techno
  • Bedfordshire
Re: Black Coolant!
« Reply #35 on: 18 February 2009, 18:40:14 »
Hmmm bit confused here oil in water usually turns white not black!  Of course if you put enough in it will but you would have other problems like oil lack coming up and a big loss of oil I mean big. I would also have thought the engine temp would rise the pump would struggle to circulate that amount of oil and areas like the heater would stop work or be hardly warm?
Why did you change the oil cooler in the first place?
You mentioned having brown water that can be several things, poor antifreeze mix allowing the block/pump impeller to corrode, very hard water or the engine has run with no antifreeze at some point.  If the oil cooler fails it normally leaks resulting in a loss of coolant if it becomes blocked for any reason you wouldn't really notice it in normally diving conditions.
Was you loosing coolant or the having cooling problems?
An oily feel to the coolant in normal for antifreeze the jet black coolant is odd but it could be one/some of your hoses are dissolving and colouring the coolant black.  Some dealers/back street types will fit any hose, a hose is a hose right..............WRONG antifreeze pretty nasty stuff and cheap hose will be dissolved.
Remove each in turn and check the internal bore if it feel tacky and your finger turns black it dissolving and this is what I think could well be your problem.
Re: Black Coolant!
« Reply #36 on: 18 February 2009, 18:41:13 »
Sounds like its not been properly flushed out when the cooler was changed (I hope he didn't charge a grand for that 3 hour job!).
So flush it out well!
ffcgary1
  • Mitcham,Surrey.
Re: Black Coolant!
« Reply #37 on: 18 February 2009, 23:16:26 »
As all ready stated twice before. FLUSH IT OUT PROPERLY :-? ::)
Jaguar XJ6
djdaveyp85
  • Geoffrey - RIP!
Re: Black Coolant!
« Reply #38 on: 19 February 2009, 00:27:33 »
Ok at the weekend its going on my drive and i'm going to run the hosepipe through it for at leasty an hour. I'm also going to get a new header tank that is clean and see if the problem still arises.
Thanks guys i'll let you know how i get on.
Re: Black Coolant!
« Reply #39 on: 19 February 2009, 07:26:37 »
It needs more than water, it needs a de-greaser to dissolve the oil
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Black Coolant!
« Reply #40 on: 19 February 2009, 08:49:39 »
Mythbusters claim that out of all the myths (coin in the carb, sugar in the fuel etc etc) bleach is the only thing that will KILL an engine, so I dont recommend using it. Some fairly liquid in the expansion tank and run it for a bit, then flush out with hose at low pressure.
Yeah although i wouldnt use bleach to flush it through the mythbusters poured lots of bleach into the engine so it mixed with the oil , not the coolant  :y
« Last Edit: 19 February 2009, 08:50:37 by Mark38 »
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Black Coolant!
« Reply #41 on: 19 February 2009, 09:05:44 »
You have any solutions for flushing an engine which is out of the car when doing oil cooler?? :)
Humbugs...
Re: Black Coolant!
« Reply #42 on: 19 February 2009, 09:11:05 »
Lots of bungs ;D
Re: Black Coolant!
« Reply #43 on: 19 February 2009, 09:21:32 »
Quite simple....remove most of the bits!
Pages: 1 2 [3]  All   Go Up
