Author Topic: Re New Car?  (Read 1122 times)
neilr
  • Barnet, Herts
Re New Car?
« on: 19 February 2009, 09:04:04 »
hi finally got more details I was told had gasket failure but this is wrong its a cam belt failure. the cars done 75000 and its a 2.5 v6. would it be worth doing and whats to look for. I realise its a big job and my main concern is setting camshafts after replacement.
Re: Re New Car?
« Reply #1 on: 19 February 2009, 09:09:53 »
I suppose it depends how much the car is worth to you. I have broken new Elites for smaller problems than a snapped cambelt :(
MutantCav
  • Gainsborough
Re: Re New Car?
« Reply #2 on: 19 February 2009, 09:30:39 »
Realistically on an M reg CDX its not worth doing...cost wise it will set you back more than replacing the car with a newer better car...
As Pete says, much better cars have been broken when in reality there is nothing at all wrong with them...for a few hundred you could easily pick up something newer and better...you could probably replace your car with a same age same spec car but with running engine etc for a couple of hundred...
If your car has sentimental value or is in very good condition then maybe worth thinking about getting the parts needed and getting a forum member to help you do the work needed...where are you located?
MutantCav
  • Gainsborough
Re: Re New Car?
« Reply #3 on: 19 February 2009, 09:33:08 »
Laurie is selling a T reg 2.5 for £275 if your near Hampshire and can pick up by end of week...
neilr
  • Barnet, Herts
Re: Re New Car?
« Reply #4 on: 19 February 2009, 09:47:11 »
the car is a v plate not the current driver it it in good condition apart from the engine. Are secondhand head available?
MutantCav
  • Gainsborough
Re: Re New Car?
« Reply #5 on: 19 February 2009, 09:50:21 »
Yeah mate, easy enough to get a second hand engine or second hand heads :) V reg probably worth doing more...sorry saw your profile and it says M reg, assumed that was the one...
Make sure you have use of a camlocking kit when you do the timing as you do need it!
Unfortunately I only have 3.0 heads atm
Page created in 0.043 seconds with 16 queries.
