Author Topic: New Rear springs ?  (Read 2828 times)
bigdods
  • Brackley
New Rear springs ?
« on: 17 February 2009, 11:58:12 »
Just been to WIM for Geo setup - blimey its miles better now (nice one tony) and it was only done in May last year. Bloody potholes and speedbumps have a lot to answer for !.
While there they found one of the rear springs was missing about 1/2" off the end, So I need to replace the rear springs.
I like the current setup , nice and comfy for the long motorway journeys so should I just go for OEM vauxhall springs ? Are they on TC (I've got a card) or do I have to pay the retail price, and any idea how much they are?
I guess the alternative would be eibachs ? Are they similar in price , would i need to change all 4 if going this route and what would that do to the ride quality and handling ?
I think most of this has been covered before but I did a search and couldnt find all the answers so apologies if this is covered elsewhere..
Cheers for any help !
Dodsy
« Last Edit: 17 February 2009, 12:00:06 by bigdods »
Re: New Rear springs ?
« Reply #1 on: 17 February 2009, 12:04:03 »
vx springs are extortionate, mv6 fronts are over 300 a pair.
Mr dtm has recommended kyb in the past...
« Last Edit: 17 February 2009, 12:04:43 by chrisgixer »
« Reply #2 on: 17 February 2009, 12:07:14 »
Self leveling suspension is the issue as it utilises a slightly softer spring compound then the standard ones.
About 200+ vat a pair.
« Reply #3 on: 17 February 2009, 12:09:42 »
I have just fitted standard springs with my SL shocks and, so far, haven't noticed anything untoward... Perhaps a slight sharpening of the rear end but not entirely sure :-/ :-/ :-/
I'll keep people up to date with any developments in the future :y :y :y
jerry
« Reply #4 on: 17 February 2009, 12:18:18 »
my 2.5v6 has just failed the mot and needs rear springs. Problem is the guy made a few phone calls and has been told that , with this car, has had problem with cheaper springs giving poor ride and excessive noise. Hes been quoted £285 plus vat for vx genuine springs which seems over the top. I got 2 new front tyres and tracking done elsewhere just and , altho feller there said he'd heard of poor ride problems due to fit of cheaper springs, said that as I dont use car for towing that couldnt see problem with KYB springs at about £85 each fitted. Dont want to bugger the ride up but havent really got the money for vx ones. Any advice guys?? :-/
        jerry
bigdods
  • Brackley
« Reply #5 on: 17 February 2009, 12:18:52 »
Didnt know vaux did gold plated springs. Blimey thats steep !  :'(
« Reply #6 on: 17 February 2009, 12:23:28 »
Have enquired at vx re mv6 suspension for mine.
As my rear end issues may be down to old front shocks and springs. It appears sl was an option on the mv6? And shares the same sl part numbers with the elite. I take is this means i can fit front mv6 front shocks and springs and reset the rear sl side hight? (the rear sl and springs are new and dont want to loose the option.)
Sorry for hijack.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 17 February 2009, 13:59:31 »
Now the weather has improved a bit, I am going to have a look at my rear suspension including looking for missing bits of springs. I had new VX S/L shockers three years ago and suspect they are shot again. I do quite a bit of heavy load carrying and towing a small trailer.
I don't really want to go to the expense of VX springs if aftermarket none s/l springs will work satifactorily. I will follow the thread with interest especially as lazydocker has done this with his car.
varche
jerry
« Reply #8 on: 17 February 2009, 16:51:53 »
Have gone for the cheaper KYB springs (apparantly they do 2 that fit, have gone for the dearer pair at £85 each fitted) rather than the VX ones. Will get them done Thursday and let you know how ride is then,
        jerry :y
hawksy
  • crewe
« Reply #9 on: 17 February 2009, 16:57:46 »
i bought a new set of rear springs last year for my 2.2 dti elite 2003 they were £ 260.68 plus £ 75.20 fitting , can't remember if they are trade club or not and can't find my tc book to confirm, regards mike
jerry
« Reply #10 on: 18 February 2009, 20:08:11 »
just had the kyb rear springs fitted at £170 and handling seems fine, if a bit stiffer. When I spoke to the fitter he reckoned the shocks werent self levellers tho, but I thought these were standard on the cdx, or if they were, maybe mine had had them replaced with standard shocks at some point? :-/
                                             jerry
« Reply #11 on: 18 February 2009, 20:11:26 »
self leveling is not standard on cdx, only Elite
« Reply #12 on: 18 February 2009, 20:22:23 »
                                             jerry
Robbing gits!
So that was a 100 quid labour for an hours job!
jerry
« Reply #13 on: 18 February 2009, 20:44:30 »
No, I had a choice of 2 kyb springs and opted for the dearer ones at £85 each fitted as opposed to the cheaper ones at about £45 each fitted. In comparison to the £285 plus vat I was quoted for the vx ones elsewhere that seemed reasonable! have used them for years tho only for tyres and exhausts in the past and never been "done" . They recently fitted a front/back/middle exhaust I'd sourced for the emina for £55 and that included some adjustments they had to make so labour costs whilst not cheap, arent totally ott either.
« Reply #14 on: 18 February 2009, 20:47:05 »
KYB only make two types of rear spring for the Omega and they are both the same price.....
.....one type for the estate and one for the saloon
