Author Topic: Parrot hands free  (Read 1185 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Parrot hands free
« on: 19 February 2009, 20:58:09 »
Thinking of have one fitted just to see if anyone knows if i will have to get an ISO connector or will the one in the car fit this system.
Thanks
Steve
waspy
Re: Parrot hands free
« Reply #1 on: 19 February 2009, 21:03:04 »
Hey Steve. How's it going matey? Will we be seeing you at the next Mids/ABS meet?
Pete
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 19 February 2009, 21:04:33 »
Thanks
Steve
Got a CK3000 fitted in mine, just needed an adapter to connect the Parrot into the prewired phone plug behind the glove box.
Only problem I had was the car was fitted with a part wired Trafficmaster loom which wasn't passing the phone signals to the HU.
Just cured it today with a new piece of loom spliced into the car wiring.
It's not such a big job that you can't fit it yourself Steve.
TuBy's new whipping boy.
SP_3.2
  • Leicester
« Reply #3 on: 19 February 2009, 21:13:13 »
Thats good does  not sound too bad of a job with that :y
HI Pete hope you are well, will be at the next meet all going well just been a bit busy. :y
« Last Edit: 19 February 2009, 21:13:54 by SP_3.2 »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #4 on: 19 February 2009, 21:18:48 »
Check you've got the phone connector behind the glovebox then you will need an Autoleads SOT-109 I think it is to connect the Parrot into it.
SP_3.2
  • Leicester
« Reply #5 on: 19 February 2009, 21:28:15 »
Cool will have a check, thanks for that , Do i just need to check at the back of the glovbox at the top of the footwell.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 19 February 2009, 21:33:30 »
Unfortunately it usually hides up behind the glovebox so you have to take that out which is a bit of a pig just to check.
