Author Topic: Front passenger door problem  (Read 1412 times)
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« on: 19 February 2009, 18:46:51 »
I have a problem with my central locking on my 2003 CD saloon.
Opened the car as usual this morning without any problem and drove off with my passenger.
Went to leave the car and front passenger door wouldn't open. The button on the door was down and wouldn't come up no matter what we did. Passenger ended up climbing out the drivers door !
When using the remote for the central locking, the button looks like it's trying to come up and unlock, but something seems to be stopping it, as it is moving slightly.
The problem is that, I assume to get at the mechanism inside, the door panel inside needs to come off, but can this be removed with the door closed, and if not....anyone got any suggestions.
Regards
Steve
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Front passenger door problem
« Reply #1 on: 19 February 2009, 21:32:25 »
Happens to mine on a regular basis been told its the solonoid. Prise off the fitting around button and a good spray into it with WD40 should do the trick.
« Reply #2 on: 19 February 2009, 21:43:22 »
^^^Agreed^^^^
« Reply #3 on: 19 February 2009, 21:53:02 »
I would NOT use WD40 ... that is a water dispersant in a solvent carrier .. the solvent can screw plastics up very quickly ... a decent light oil ( 3-in-1 ?? ) would be better IMHO
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« Reply #4 on: 19 February 2009, 22:31:19 »
will give it a go and see what happens
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #5 on: 19 February 2009, 23:54:28 »
If you put the wee attached straw on the can you can spray it directly into the hole. has never done any damage to my door.
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« Reply #6 on: 20 February 2009, 12:06:06 »
Thanks very much guys - a squirt in the hole (so to speak) did the trick.
I can now use the passenger door again  ;D
Steve
