Author Topic: Brake pads.  (Read 1690 times)
bighed
  • Shropshire
Brake pads.
« on: 20 February 2009, 07:50:33 »
Recently had BRAKE PADS come up on mid display. been told its only front pads with sensors on? Do all mig pads come with sensors? Anyone got a linky to who they have used in past please??  :y
Re: Brake pads.
« Reply #1 on: 20 February 2009, 08:02:07 »
on prefacelifts, 1 sensor on each inboard pad at front.  Sensors are seperate item from pad - just clip in to pad.
bighed
  • Shropshire
Re: Brake pads.
« Reply #2 on: 20 February 2009, 08:05:19 »
Well as its come up on mid that means they will be fubared. Is that right?
Re: Brake pads.
« Reply #3 on: 20 February 2009, 08:09:32 »
yes, the sensors have worn through due to either low pads (down to last 1/3rd or so) or badly lipped disc.  If the disc, change disc/pads/sensors.  If just the pads, change pads and sensors.
bighed
  • Shropshire
Re: Brake pads.
« Reply #4 on: 20 February 2009, 08:22:37 »
Thanks TB  :y
Re: Brake pads.
« Reply #5 on: 20 February 2009, 11:50:18 »
Exactly the same as your Senator.
bigdods
  • Brackley
Re: Brake pads.
« Reply #6 on: 20 February 2009, 12:10:48 »
Is it different on facelifts then ? While WIM had the front wheels off this week I had a good poke around - There was a cable on both the n/s and o/s connected to one of the pads, so I assumed sensors on both sides ?
Just useful to know as they are getting low and will need to replace disks too when the pads are changed so when i pick up all the parts want to make sure I get the right number of sensors !
Dodsy
Re: Brake pads.
« Reply #7 on: 20 February 2009, 12:14:33 »
Late facelifts have just one sensor, earlier cars have 2 like preface lifts  :y
Re: Brake pads.
« Reply #8 on: 20 February 2009, 13:51:54 »
Dodsy
On prefacelifts, 1 sensor on each inboard pad.  So 2 sensors.  From 2001, only 1 sensor fitted.
