Author Topic: Dash removal help?  (Read 1237 times)
Black Knight
  • York
Dash removal help?
« on: 20 February 2009, 14:50:09 »
How on earth do you get the bloody dash out without some severe force?
Vents are out 2 + 1 screws removed and additional screw above stering coloum.
Got some movement but sure I'm gonna snap that lower tab if I pull any harder. Is there a particular technique for doing this?
« Last Edit: 20 February 2009, 15:01:29 by Black_Knight. »
Re: Dash removal help?
« Reply #1 on: 20 February 2009, 15:01:56 »
Lower steering column to lowest height if plastic tab of dash is catching...
Black Knight
  • York
« Reply #2 on: 20 February 2009, 15:06:23 »
Ta, done that but still seems far too high. It was a job just to get a screw driver in.
Can force the unit upwards clear of the catch but just deosn't seem to be enough room to carefully remove. May well come out if I just pull hard enough but don't want to risk damaging it.
Do you tilt it out? Top or bottom first? Is there enough run on the cables behind or do I need to disconect them first somehow?
I lose my temper far too easy and thats why I rarely undertake shit like this.
« Reply #3 on: 20 February 2009, 15:14:23 »
only cable behind is the one for the display (1 plug on all 1999 cars).  So I alwasy pull left side out a little , get my hand in behind and unplug the MID, then gently wiggle it out, gently assisting it around any cables on steering column it may ctach
Black Knight
  • York
« Reply #4 on: 20 February 2009, 16:00:23 »
Thanks matey,
Thats was a help, finally got it out, didn't need to unplug the display, rested the other end on the gear lever whilst I drove round looking for somewher with the correct lamps...always thinking ahead.....Could only find 3W lamps so replaced all four with those. Just a much of a bugger to get back in but I'm sure it will be far easier next time round.
Thanks again. :y
