Author Topic: omega 2.5 cutting out  (Read 1686 times)
cpeden
  • lincolnshire
« on: 17 February 2009, 19:44:24 »
Please can anyone advise we are running out of ideas the engine just cuts out while driving. I did the paperclip test and it didnt show anything. I have read various ideas on here and have cleaned out everything advised and fitted a new icv valve. It is still cutting out.  Changed spark plugs and ht leads after seeing the leads were covered in oil from leaking gasket which we have also changed along with the rocker cover. Did the paperclip test again and code 17, 21, 31 & 57 came up.  We have now bought a new crankshaft sensor but still cutting out.  How many things do we have to keep changing and if we drive it like this will it do any harm? Please help running out of money fast!
Re: omega 2.5 cutting out
« Reply #1 on: 17 February 2009, 20:15:43 »
Knock sensor on passenger side. Have you trapped the cable when doing camcovers :question
cpeden
  • lincolnshire
« Reply #2 on: 17 February 2009, 20:25:20 »
yes it was but have got it out .  rubber coating was damaged but not damaged the wires.  would this make any differance to cutting out as it wasnt damaged before
« Reply #3 on: 17 February 2009, 20:31:29 »
Have you checked the connection to the throttle position sensor and the connection on the ICV. Knock sensor shouldn`t cause cutting out. Is it starting OK :question
« Last Edit: 17 February 2009, 20:35:17 by RobG »
cpeden
  • lincolnshire
« Reply #4 on: 17 February 2009, 20:36:16 »
yes it is connected and we have never had any trouble with it starting
cpeden
  • lincolnshire
« Reply #5 on: 18 February 2009, 13:29:31 »
should i take it and get the codes cleared and read properly, will that tell us what is wrong
astonmartin
  • southeast london
« Reply #6 on: 18 February 2009, 14:39:28 »
mine has the same problem i have a v6 3.0l i have chang my chank sensor and is still doing it have bin told it may be the air mass sersor try that it may help
« Reply #7 on: 18 February 2009, 19:34:42 »
Cpeden ....  your avatar is blocking off half your posts .... :(  makes reading your popsts a tad tricky !!
site limit is 110 x 110 ... yours is 240 x 320 !!!
McJOHN
  • Prague (CZ)
« Reply #8 on: 20 February 2009, 18:16:17 »
Hi,
First time must tested cramshaft conector.
Position 1-2 = 500-800 Ohm.
If resistance  less or larger it is wrong.
Me helped if this sensor dismonted, because it is dirty, cleaning and next mount back.
http://www.mhonc-fotogalerie.ic.cz/car/crankshaft01.pdf
Undrestand me? :-))))))
McJOHN 8-)
« Last Edit: 20 February 2009, 18:17:21 by McJOHN »
Omega A C20NE; Omega B X25XE; Omega B X25XE
