Author Topic: Headlight switch illumination  (Read 1004 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« on: 20 February 2009, 20:57:11 »
I've removed the headlight switch as it's not illuminating very well.
There's a small grey bulb, with a hexagonal profile on it's GREY holder.
Is this the correct colour holder?
What's the correct bulb rating?
This bulb looks to be of the same type as those used in the warning lights, but with different colour holder.
Ive also noticed that the indented off/side/head symbols at the top of the switch illuminate via the ignition key. Is there also a bulb here that can be changed?
All help appreciated ........
minilandrover
  • france
  • My other car is a HALF SIZE LANDROVER
Re: Headlight switch illumination
« Reply #1 on: 20 February 2009, 22:10:56 »
hello yas there is as when i got my car lots of the lottle bulbs were burnt out, they all need to be replaced if some are going a silver colour , caused by over voltage. incedently the center switches can be made brighter by removing the grey internal cap's inder the logo. this make for a nicely lit car, not over bright bet really readable. :y
colin
want a laugh?  take a look at landrover v tree on www.youtube.com     this how i do gardening with a landrover,   im building a petrol half size army light weight landrover for fun  250 kgs of bad attitude
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 20 February 2009, 22:15:28 »
yep right one 1.2 watt ! and yes the other bulb can be changed there capless 2 watt  :y
Seth
« Reply #3 on: 20 February 2009, 23:41:25 »
Hang on here ......
Right Mark, firstly the grey capped bulb is 1.2 watt, (am I correct?)
Secondly, the other bulb, (for the switch symbols), is a capless 2 watt jobbie, (am I correct again?). How do you access this second bulb? Cheers in anticipation .... 1
markey mark
« Reply #4 on: 21 February 2009, 07:55:12 »
yes grey capped is 1.2 watt there is also a orange capped and that is 2 watt  and the illumination lamps are capless 2 watt if you take the side panel off the dash you can see the bulb holder :y
