Author Topic: Noisey lifters again  (Read 1509 times)
Omega man 2
« on: 20 February 2009, 21:58:26 »
500 miles after rebuild, lifters still sound like a diesel.
Going to change the oil tomorrow and take it on a 100 mile run on sunday. If they don't change at this stage are they fubar?
Re: Noisey lifters again
« Reply #1 on: 20 February 2009, 23:46:22 »
No experience of this, but just wonder if oil pressure is ok, oil pump tired? Oil pick up clear, are they receiving enough oil basically?
« Last Edit: 20 February 2009, 23:48:38 by chrisgixer »
« Reply #2 on: 21 February 2009, 00:22:08 »
IIRC there are 2 different types of lifter, 2 different types of oil pump and 2 different types of valve in the oil gallery that feeds them, so if the head / lifters have been changed perhaps you've got the wrong combination now?
Failing that, get the oil pressure checked, or try taking the lifters out and cleaning them. :-/
EDIT: Just noticed it's a 4 pot, so the above may be rubbish. ::)
« Last Edit: 21 February 2009, 00:22:57 by Kevin_Wood »
« Reply #3 on: 21 February 2009, 08:46:11 »
I would check the oil pressure.
A single noisey lifter I can understand.....a full set is another cause!
Omega man 2
« Reply #4 on: 21 February 2009, 09:56:23 »
Defo not a full set ;D
just two or three. it did settle down alot in the first half hour but hasn't got any quieter since :-/
Page created in 0.029 seconds with 20 queries.
