Author Topic: Speedo swappable or whole clocks?  (Read 1143 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« on: 20 February 2009, 22:44:56 »
Pretty much as it says - can just the speedo be swapped with some dismantling, or do you need to swap the whole unit as one?  Also...are the speedo units set to each engine/axle combo or do they all read the same?
Might be able to get a 3.0 Manual speedo (ex-plod, so calibrated) and wondered if it'll fit the 2.5TD Auto pack...and work!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
    • 530D M Sport, 330i Coupe
Re: Speedo swappable or whole clocks?
« Reply #1 on: 20 February 2009, 22:53:09 »
Ex Plod go up to 150 on the speedo, I think the TD one go up to 140?
The rev counter and speedo is one complete unit and can be swapped between units.
philhoward
  • Staffs
« Reply #2 on: 20 February 2009, 22:56:00 »
Bugger..as the TD tacho doesn't go as high..but would it still read correct?
Not that i'd ever get to 150mph in a TD (chipped or not), just there may be one (or even 2..) going for peanuts I know of...
« Reply #3 on: 20 February 2009, 23:01:56 »
Need to clarify that with TB or MDTM, not sure if it would need coding or not, i'm guessing not as the speedo drive signal is from the rear ABS sensor IIRC.
Going to swap mine as the rev counter is 'sticky' and not reading correctly. If you can get hold of two replacements for peanuts then i'd be interested in buying one off you to see if I can dismantle one enough to see what repairs are possible.
« Reply #4 on: 21 February 2009, 10:16:59 »
whats the gain?
rev counter will read 'dangle berries' btw, and I reckon the speedo will as well.
philhoward
  • Staffs
« Reply #5 on: 21 February 2009, 10:32:17 »
Thats the answer i wanted, TB - like for like only then..
The gain was a free one vs paying for one..
« Reply #6 on: 21 February 2009, 10:40:10 »
Do even the tacho's have the same range? There's a difference in range between SWMBO's petrol Astra & my TD Astra tacho's, my clocks fitted her car and gave a reading, but not the correct reading. Her speedo is ABS driven and mine is (electrically) gearbox driven.
