Author Topic: ICV bracket  (Read 2086 times)
BazMV6
  • Silverstone
ICV bracket
« on: 15 February 2009, 15:17:03 »
How on earth do I get to the ICV bracket to remove it??  Seems to be a E8-ish screw holding it in place - but I can't get a socket on it, and no room to even swing an adjustable spanner...   How much do I nee to remove first?  Is it an engine out job??!?   :o
This space left blank for your own message...
kevpuk
  • Poole
Re: ICV bracket
« Reply #1 on: 15 February 2009, 16:40:25 »
ICV = Idle Control Valve ? Assuming this, then you do not need to remove the bracket, just pul it out from the rubber housings ? Certainly how I did it, albeit with some stretching.....
BazMV6
  • Silverstone
Re: ICV bracket
« Reply #2 on: 15 February 2009, 17:02:12 »
Ah - but that's the problem - I'm trying to replace the bracket itself, since the old one has split.  Even more so now that I've hacked part of it away trying to get to the fixing...   :(
MutantCav
  • Gainsborough
Re: ICV bracket
« Reply #3 on: 15 February 2009, 17:06:31 »
Yeah its a bugger to get to the e8 bolt...just push some stuff out the way :)
Dazzler
  • Haverhill, Suffolk
Re: ICV bracket
« Reply #4 on: 15 February 2009, 17:28:33 »
It can be done, just carry on you will do it ;)
BazMV6
  • Silverstone
Re: ICV bracket
« Reply #5 on: 15 February 2009, 17:57:14 »
There's some plastic "trunking" in the way - I can easily detach this at the front, but don't know how it's fixed at the back?  If I could get that out of the way I'm sure I could do the job.
Dazzler
Re: ICV bracket
« Reply #6 on: 15 February 2009, 18:16:32 »
That is the cable tray. The rear bolt for it is at the rear right hand corner of the plenum, a small torx bolt it is.
Remove that one and the one at the front and the cable tray will move a little, just enough for your bolt ;)
BazMV6
  • Silverstone
Re: ICV bracket
« Reply #7 on: 15 February 2009, 19:48:08 »
Thanks Dazzler  :y - getting a bit dark now, so will give it another go later in the week.  The ICV is held on with rubber bands for now...  :-?
BazMV6
  • Silverstone
Re: ICV bracket
« Reply #8 on: 21 February 2009, 15:14:07 »
Done it!  By releasing the cable tray at both ends it can be pushed down sufficiently to get a socket and extension on the bolt.   :y
