Author Topic: 2.0 X20XEV crank sensor replacment?  (Read 1217 times)
ianph
  • Sutton,Surrey
« on: 22 February 2009, 04:42:56 »
Is there a how to on this ?
I did check maintenance guide but couldnt find one for my motor.
Would someone be kind enough to explain how to do it or locate the link please?
Re: 2.0 X20XEV crank sensor replacment?
« Reply #1 on: 22 February 2009, 10:04:30 »
does it have a/c?
ianph
  • Sutton,Surrey
« Reply #2 on: 22 February 2009, 19:58:21 »
Yes it has AC
Omega man 2
« Reply #3 on: 22 February 2009, 20:19:49 »
You need to remove the fan belt. Then undo the A/C compressor and move it out of the way.
Remove the bracket that the compressor is mounted on. Its held on by 4 bolts
1. behind the compressor,
2. near the exhaust manifold,
3.one through the engine bracket
4. Cant remember
The crank sensor is located between the Pas pump ans the A/c compressor right on the block.
star_whites
  • Rotherham
« Reply #4 on: 22 February 2009, 21:01:29 »
It can be done without removing all that if you dont mind losing a bit of skin. Remove the dipstick pipe and get a 1/4 drive flexi ratchet and you can just get in to remove it.
Like I say though you do tend to loose a little bit of skin off your fingers  ;D
