Author Topic: crankshaft sensor ?  (Read 3034 times)
deks
  • Durham
crankshaft sensor ?
« on: 21 February 2009, 17:48:48 »
well today i took the family for a day out !! got about 20 miles away and the car started to lack power (felt like it was running on 5 instead of 6 ) so i checked around the engine but found nothing ,so i called rac out .The guy plugged in his computer and it is saying crankshaft sensor ,can anyone tell me where it is and what sort of job it is to do please ,also is it a vx part or can i get one from motor discount  shop
Re: crankshaft sensor ?
« Reply #1 on: 21 February 2009, 17:51:22 »
Do you have an EML light on ???
also .. check for stored codes by doing the "paperclip" test
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
let us know the results .. I'm always hesitant about instant diagnostics ....  :(
« Reply #2 on: 21 February 2009, 17:52:24 »
Get genuine Vx.
Bolted into engine passenger side near oil filter & runs up to electrical connector under scuttle behind plenum.  Fairly easy to do on V6.
« Reply #3 on: 21 February 2009, 17:55:35 »
Its beside the oil filter,held on with 1 torx bolt.If replacing it read the fitting guide on the forum,as routing the wiring as per original is very difficult and also a very bad idea,as it fries the wiring.
Need to get one from VX,around £65 iirc.
Before you replace it do the paperclip test to confirm diagnosis,should give a code 19 (with engine running).
P.Sdont bother trying to remove the old onefrom the car,just leave it attached to the loom and put the new one on as per the guide. :y
deks
  • Durham
« Reply #4 on: 21 February 2009, 18:16:05 »
hi guys thanks for the help ,i am getting my shoes on now to go and do a paper clip test (will let you know results ) but i cannot find the fitting guide as stated by albitz .cheers back in half hour !!
« Reply #5 on: 21 February 2009, 18:35:53 »
deks
  • Durham
« Reply #6 on: 21 February 2009, 19:19:06 »
ok i am back from the paper clip test and all i am getting is 12 over and over again , and nothing else ,and thanks for the link Albitz .this is now got me pulling my hair out ,as R.A.C says crankshaft sensor ,but paper clip not showing anything !!!! but sill running but very rough as if only firing on five
Welung666
« Reply #7 on: 21 February 2009, 19:23:26 »
Check spark plug wells for oil :y
deks
  • Durham
« Reply #8 on: 21 February 2009, 19:25:59 »
will do that again in the morning ,i hope it is not that as i have just done the cam cover seals on the drivers side but did check drivers side earlier ,cheers
« Reply #9 on: 21 February 2009, 19:26:21 »
If you keep getting 12 then there are no faults stored,which is good news.As weelung said ,you should check for oil in plug wells (caused by blocked breathers)which can damage the plugs/leads/ dispack.
« Last Edit: 21 February 2009, 19:27:06 by albitz »
deks
  • Durham
« Reply #10 on: 21 February 2009, 19:34:40 »
cheers ,well looks like a strip down again in the morning of the beathers ,and a good look at plugs etc while i am that far ,i will chuck a set of new plugs in while i am on with it ,getting well sick of this car now ,but i need it up and running for next week to get to aberdeen and back ,thanks again
deks
  • Durham
« Reply #11 on: 22 February 2009, 13:17:32 »
just a update ,stripped down the breathers ,they seem ok nice and clean ,so went a bit further ,stripped out dis pack ,and have a split and rusting under number 1 and 4 ,so now trying to get hold of one ,as i think this is the problem if it is not ,well it needs changing anyway
« Reply #12 on: 22 February 2009, 14:15:10 »
That is quite common and almost certainly the cause of the rough running.Loo-knee/elite pete/markey mark/mutantcav all break omegas
worth a pm to them before you go and pay vx prices. :y
deks
  • Durham
« Reply #13 on: 22 February 2009, 14:19:45 »
hi Albitz ,thanks for that i wil ontact them ,i have marks e mail ,i have called a few places today locally and the wanted to know if square or round holes !!! any idea what they mean by this ?
« Reply #14 on: 22 February 2009, 14:23:43 »
I think it refers too the wiring plug,there are different types,you could take it off and have a look or if you give a vx dealer your reg.no. they may be able to give you the correct part no.for your car. :y
Page created in 0.029 seconds with 16 queries.
