Author Topic: Help With Live Data Results  (Read 2250 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« on: 22 February 2009, 11:13:55 »
Ok here are my results to try and fix my constant P0170 lean exhaust code after about a 10 mile run.
Coolant Temp 85c - 97c throughout test.
@ idle
Mass Air   0.51 - 0.73 V    10 kg/h
Intake Air Temp  28c
EGR Position Feedback  0.80 V
O2 sensor Bank 1   745 - 862 mV Lean
O2 sensor Bank 2   647 - 804 mV Rich
O2 Loop Open
Short Term Fuel Trim   0%
Battery  13.1 V
@ 2500 rpm
Mass Air   1.61 - 1.69 V    31 kg/h
Intake Air Temp  32c
EGR Position Feedback  1.04 - 1.06 V
O2 sensor Bank 1   39 - 59 mV Lean
O2 sensor Bank 2   98 mV Lean
O2 Loop Open
Battery  13.2 V
Couldnt find anything for long term fuel trim
No MIL on but code stored P0170-(02) Lean Exhaust Present
Can someone with a known good MAF or O2 sensors compare results ?
Please help as this is driving me mental  :D :D  :y
« Last Edit: 22 February 2009, 11:29:12 by Mark38 »
Proz
Re: Help With Live Data Results
« Reply #1 on: 22 February 2009, 14:06:38 »
Anyone  :-/
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #2 on: 22 February 2009, 14:09:53 »
Curious as to why is was in O2 open loop - if it was up to temp, i'd expect it be closed loop...
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Proz
« Reply #3 on: 22 February 2009, 14:29:34 »
So was i but i have no idea what i means  :-[
« Reply #4 on: 22 February 2009, 15:17:04 »
Can you get a graph of the o2 sensors, as a point in time reading isn't that useful I'm afraid...
Proz
« Reply #5 on: 22 February 2009, 15:38:47 »
Im not really sure how i would go about it .... i dont know if my tool has that function ... i'll have a look when i get some time to connect it up again   :y
Proz
« Reply #6 on: 22 February 2009, 16:24:43 »
I was hoping it was going to point to something obvious ....  :'( :'(
Proz
« Reply #7 on: 22 February 2009, 16:26:49 »
Is it possible using my laptop to record the screen showing the sensors... is there a screen capture or something ?
Proz
« Reply #8 on: 22 February 2009, 22:07:59 »
Intake Air Temp  28c...is this normal ? .  Outside temperature was nowhere near that in sunny scotland  :o
« Reply #9 on: 22 February 2009, 23:04:28 »
Intake air temp looks suspicious, unless the car had been parked with a hot engine and bonnet closed before the test. In any case, it only causes a small correction. Coolant temperature is much more important.
MAF values look plausible, although a comparison with a known OK 2.2 would help.
Was the engine hot during the test? Had it been running for a few minutes or just started? Just wondering if O2 Loop Open ever changes to O2 Loop Closed? Normally they go closed loop pretty quickly after startup unless stone cold.
Proz
« Reply #10 on: 23 February 2009, 06:41:46 »
The car had just been on a 10 mile run to get it warmed up for the test then sat idling for maybe 5 minutes till i got set up and all through the test .... bonnet was never open ( i never thought to open it ).  Im sure when i was just playing with the tester that i did see it in Loop Closed at some point .... God i hate this car now  :D :D :D :'(
« Reply #11 on: 23 February 2009, 09:14:56 »
Intake air temp should drop quite quickly when revving.........
It looks a bit to high for more liking.
Proz
« Reply #12 on: 23 February 2009, 18:16:03 »
It went up when it was at 2500 rpm  .... does this point the the maf ??
Car is starting to get me down now  :'( :'(  ... took two or three turns to start at work there . Always used to fire on first turn ...  think i'll look out the matches and go somewhere remote  ::)
Proz
« Reply #13 on: 24 February 2009, 18:46:18 »
Aww i give in with this thing  ..... flat and sluggish   .. even for a 2.2  ....  :'( :'( :'( :'(
